Video Overview
This teardown is not a repair guide. To repair your Microsoft Surface Pro X, use our service manual.
  1. Microsoft Surface Pro X Teardown, Microsoft Surface Pro X Teardown: step 1, image 1 of 2 Microsoft Surface Pro X Teardown, Microsoft Surface Pro X Teardown: step 1, image 2 of 2
    • Apart from that sweet kickstand, we're not sure what to expect here—and that's a good thing. Our teardown unit boasts the following specs:
    • 13" PixelSense display with 2880 × 1920 resolution (267 ppi)
    • Microsoft SQ1 3.0 GHz ARM processor (based on Qualcomm's Snapdragon 8cx) with a Microsoft SQ1 Adreno 685 GPU
    • 8 GB of LPDDR4X RAM (16 GB optional)
    • Removable 128 GB solid state drive (256 GB or 512 GB optional)
    • 5 MP and Windows Hello front-facing cameras, and one 10 MP rear-facing camera
    • Two USB-C ports and one Surface Connect port (headphone jacks are apparently not professional)
    • Wi-Fi 5 802.11ac, Bluetooth 5.0, Gigabit LTE
  2. Microsoft Surface Pro X Teardown: step 2, image 1 of 3 Microsoft Surface Pro X Teardown: step 2, image 2 of 3 Microsoft Surface Pro X Teardown: step 2, image 3 of 3
    • Unlike the fairly-iterative Surface Pro 7 released last month, the Pro X is a complete redesign—the first in many years. And it comes with a new model number: 1876.
    • What a great year, 1876. Feels like just yesterday we were tearing down Alexander Graham Bell's new "telephone."
    • If you need a teardown TL;DR, here's an X-ray overview from Creative Electron showing everything on our agenda.
    • Compared to the Pro 7, we note the Pro X's rounded corners, narrower profile, and reductified port selection.
    • If you're in the market for a thin professional Windows tablet, wave goodbye to the USB-A port, MicroSD card slot, and headphone jack. USB-C is the future, it seems.
    “ …reductified port selection” Surely you mean “reduced port selection”?
    Roscoe P - Reply
  3. Microsoft Surface Pro X Teardown: step 3, image 1 of 3 Microsoft Surface Pro X Teardown: step 3, image 2 of 3 Microsoft Surface Pro X Teardown: step 3, image 3 of 3
    • With the kickstands raised, we can see that the Pro X gets a sleeker hinge—likely shaving off precious thickness.
    • And if you look closely, you'll find the faint outline of what can only be described as a secret trap door in the Pro X. Lucky for us, it's not guarded by a three-headed dog.
    • We poke the (magnetically secured!) trap door with our SIM eject bit, and...
    • Voilà! Underneath, an SSD (held down by a T3 screw) and a SIM slot!
    • And hey, this SSD looks super familiar. A quick comparison with the 256 GB drive we pulled from the Surface Laptop 3 confirms both devices are using the same drive. Standardization is great for repairs!
    • As an experiment, we try powering on the Pro X sans-SSD, and... no sign of life. We wouldn't expect it to boot up—but it's so dead, we sort of suspect the SSD acts as a battery kill switch like we found in the Laptop 3.
    • Unlike the Laptop 3 with its hidden screws, we don't find any fasteners lurking under this kickstand. Alas, this probably won't be a magical opening experience. We arm our iOpeners and brace ourselves for heavy adhesives...
  4. Microsoft Surface Pro X Teardown: step 4, image 1 of 3 Microsoft Surface Pro X Teardown: step 4, image 2 of 3 Microsoft Surface Pro X Teardown: step 4, image 3 of 3
    Tool used on this step:
    iMac Opening Wheel
    $7.99
    Buy
    • But first—a little suction (maybe more than a little) to try and lift the display near the speaker grille.
    • Look ma, no heat! Perhaps our iOpeners can take the day off—we're able to cut right in, iMac-style.
    • No goopy tendrils hold this display down—it comes off clean!
    • This friendly, cuttable foam adhesive is truly an improvement over previous Surface Pro devices—and pretty much all other tablets with glued-down screens. High heat, furious cutting and prying, glue-covered tools, and (frequently) accidentally cracked screens are "features" we will happily kiss goodbye.
    • Not pictured: the teardown team performing a celebratory dance around the photo table. We never thought we'd get into a Surface Pro this easily.
    Where can I purchase a new screen?
    Luis A. Calderon - Reply
  5. Microsoft Surface Pro X Teardown: step 5, image 1 of 3 Microsoft Surface Pro X Teardown: step 5, image 2 of 3 Microsoft Surface Pro X Teardown: step 5, image 3 of 3
    • While relatively painless, this opening procedure is not without hurdles—we see a few flex cables along the bottom of the display, dangerously close to the path of our cutting tools.
    • That said, it gets even painless-er when we start removing the adhesive. It peels off like magic—no mess! This is the kind of change we've been pleading for. If you must glue together a super thin, space-constrained device, this is how you should do it. (But don't do it on a desktop, okay? Because that's just lame.)
    • Our excitement is real, but let's pause to peruse these display chips. We've got:
    • Microsoft X904163 and X904169 display drivers
    • Winbond Q16FWUXB2 1921-681C DR80006
    • Analogix ANX2684 1920 C975AA
    • SiW SW50014A 8266631T 1844
    • SiW SW5077 J004370V 1920
    Looking at this in the lower right I only see a display cable, however I've discovered after years of issues that applying pressure right at the display cable causes my keyboard to start working again, but only if I'm not charging via USB-C. I suspect its a grounding issue but I can't be sure, I don't suppose you have any more detailed information or pictures of that area?
    Dale Barnard - Reply
  6. Microsoft Surface Pro X Teardown: step 6, image 1 of 3 Microsoft Surface Pro X Teardown: step 6, image 2 of 3 Microsoft Surface Pro X Teardown: step 6, image 3 of 3
    Pro Tech Toolkit
    $74.95
    Buy
    • We came armed with our entire Pro Tech Toolkit, but only need a single Torx bit to twirl away the heat sink screws.
    • Here's one thing we're glad Microsoft didn't change: All the screws so far are just Torx. That was the previous Surface Pro's sole positive repairability point, and it's good to see it return.
    • Supporting the heat sink is an interesting bit of abstract art intermediate frame-age. We briefly pause to contemplate its meaning before pulling it away from the board.
    • With the heat sink and quite a few shields and screws out of the way, the motherboard slides out. Time for some silicon sleuthing!
  7. Microsoft Surface Pro X Teardown: step 7, image 1 of 1
    • Here's what we dug up:
    • Samsung K3UH5H50AMJGCL 4 GB LPDDR4X RAM x2, for 8 GB total
    • NXP LPC54S00TJ EV180 microcontroller
    • Macronix MX25U1635E serial NOR flash memory
    • Winbond 26Q256JW 256 Mb serial flash memory
    • Qualcomm SDR8150 RF transceiver and modem
    • Qorvo 78052 14CEM RF Fusion MHB
    The RAM module is Samsung (SEC) , not SK Hynix.
    iosifmila - Reply
    Great catch!! Don’t know how we missed that one. I’ve corrected it in the TD.
    Taylor Dixon -
  8. Microsoft Surface Pro X Teardown: step 8, image 1 of 3 Microsoft Surface Pro X Teardown: step 8, image 2 of 3 Microsoft Surface Pro X Teardown: step 8, image 3 of 3
    • The back side of board is devoid of interesting silicon, but we can't help but notice the strange silver jumper wire clinging to it. Hey wait a minute, this thing actually looks kinda familiar.
    • What's it for? You're welcome to inspect where it's routed and try to guess!
    • We think it may be a shielded diversity antenna of some kind, with a grounded exterior to insulate RF to and from the interior signal lead. The accompanying sticker NEW SAM could be labelling the wire as a Surface Antenna Mount.
    • That said, NEW SAM could be anything: Super Activity Monitor; Silver Aerobic Master; Slippery Agile Meerkat; Solidified Aerodynamic Meter ... The possibilities are endless. Leave your NEW SAM guesses in the comments below.
    NEW SAM actually refers to their new intern Sam, who you should blame if you see any RF issues.
    Nirav Patel - Reply
    Self Addressed Memevelope
    Sam Handwich - Reply
    It is the new Microsoft Sam, obviously. https://en.wikipedia.org/wiki/Microsoft_...
    jonasaeggen - Reply
    If I’m thinking right, that cable is used to … well, connect the two coaxial connectors. Probably that a surface trace will bring too much interference or something
    Xavier Jiang - Reply
  9. Microsoft Surface Pro X Teardown: step 9, image 1 of 3 Microsoft Surface Pro X Teardown: step 9, image 2 of 3 Microsoft Surface Pro X Teardown: step 9, image 3 of 3
    • We're used to seeing some fancy mechanics driving the kickstand hinge in these Surface Pros, but this time we're treated to even more fancy mechanics.
    • The SSD cover sits on one side of a tiny see-saw, waiting for a friendly SIM eject tool or paperclip to come along and sit on the other side. When that happens, the see-saw pushes the SSD cover away from the case, and bam! Just like that you can upgrade your storage.
    • When we're done at the world's smallest playground, we move over to the SSD interface and SIM reader, which come out as one module.
    • We're intrigued by how much space this module takes up, and all the more impressed that Microsoft carved out the necessary real estate to include such a repair-friendly feature in a tablet as thin and light as the Pro X.
    Probably cut the room of the battery if you ask me.
    They could totally route the ribbon cable on top of (or under) the battery (if it was a bigger size), but this way or that it’s the way it is right now
  10. Microsoft Surface Pro X Teardown: step 10, image 1 of 3 Microsoft Surface Pro X Teardown: step 10, image 2 of 3 Microsoft Surface Pro X Teardown: step 10, image 3 of 3
    • Step right up and get yer battery specs! We spent long enough wrestling with the last uberglued Microsoft battery to know better than to mess with this one. We opt to leave it be.
    • This quad-cell, 38.2 Wh battery is unsurprisingly smaller than the 45 Wh battery in the Surface Pro 6, and just slightly bigger than the 12.9" iPad Pro's 36.5 Wh twin-cell.
    • What's left? Modular USB ports, flanked by the kickstand hinge mechanism and the case buttons. And at the far end lies the Surface Connect port—also modular.
    • You may be surprised to read the word modular so much in a Surface Pro teardown. So are we! We've done some deep breathing and pinched ourselves multiple times, but this does appear to be reality.
    • If only they could inno-vent some way to secure that battery in a more repair-friendly way. Maybe next time?
    The battery could be easily secured with a metal plate screwed down by a couple Torx screws. Maybe even an expanded heat sink plate, like the Pro 4 had.
    Surface Rescue - Reply
  11. Microsoft Surface Pro X Teardown: step 11, image 1 of 2 Microsoft Surface Pro X Teardown: step 11, image 2 of 2
    • Ta-da! That's all for now, folks. Here are all the little bits of this Surface.
    • It would seem that Microsoft has placed at least one foot on the repairability train—between this Pro X and the Laptop 3, we can hardly believe all the repair-focused changes they've made!
    • The SSD is truly user-replaceable, requiring only a SIM eject pin and a T3 driver—no need to remove the screen. That’s awesome to see in such a slim form factor. As a bonus, it’s the same SSD as in the Laptop 3, meaning more standardization and better support from third parties.
    • In a first for tablets, the display is held down with friendly foam adhesive that doesn’t require heat or solvents to remove. We still don’t like adhesive, but this is a fair compromise on a tablet.
    • What does all that mean? Time to give this thing a score.
  12. Final Thoughts
    • The user-removable SSD makes for easy upgrades and data security that doesn't require device destruction.
    • To the extent that screws are used, they are all standard Torx fasteners.
    • Many components are modular and can be replaced independently.
    • (Almost) all repairs require display removal, with an improved procedure that needs no heat, but necessitates careful prying.
    • The battery is firmly glued in place, with its connector pinned under the motherboard—requiring near-total disassembly for service.
    Repairability Score
    6
    Repairability 6 out of 10
    (10 is easiest to repair)
Taylor Dixon
67,119 Reputation
94 Guides authored
26 Comments
You guys sound truly excited… So am I while reading this. A big win for the repair community and consumers as a whole!
Anan Venasakulchai - Reply
Very cool. I am considering getting one of these for my wife so she has a lightweight device to write on when we travel. Now I’ll take a closer look! Thanks!
Tom - Reply
What holds the display in place? I did not understand from the text
Andru Nl - Reply
Hey Andru! Sorry, the details may be a little murky amidst our excitement! Adhesive holds the display in place, but it’s a very nice foam adhesive that doesn’t require heat or excessive prying to separate. All the previous Surface Pro devices use a tacky adhesive that is very difficult to separate without damaging the display.
Taylor Dixon -
The RAM module is made by Samsung (SEC) , not SK Hynix.
iosifmila - Reply
Repairability is good. Too bad it runs OS which is subpar for tablet use.
Yaffa0 - Reply
Woah. Modular SSD on Surface? Sounds like a go-to.
Any idea what the foam & adhesive are? I’m a hardware engineer so I’d like to try to use it.
Thomas Hoye - Reply
Weird how the Surface Pro X has all the glorious features of repairability, but the Surface Pro 7 is just another giant glob of glue and nothing else.
Also: Assuming the SSD cover is aluminum, an easy performance fix to prevent throttling on such a tiny SSD is to put a thermal pad between the SSD and its cover.
Ethan Zuo - Reply
That are good news. (=
Easy changable batteries in the future and it is on the way to be the best tablet to buy.
TheLOD2010 - Reply
In Step 11, the photo miss the antenna module.
Jay - Reply
The Surface Pro X uses the M2. 2230 SSD card form-factor. But for the life of me I can’t find any availability on the 2230. Anyone know someone who sells them?
richard.brock57 - Reply
Did the RAM soldered into Logic Board?
Kin Ping Chan - Reply
what do they use for power, buck-boost, PMIC, etc.?
Erik Nordstrom - Reply
Microsoft mentions SSD removal on there website as a selling point but doesn’t mention how to remove it. Looking at these hard drive price differences it it is a big jump in price at Microsoft but not nearly as high if purchased from other sources and upgraded yourself. Wonder why that is. How hard would it be to upgrade the ram?
mark m - Reply
Hi, can someone help me where i can order a replacement display for the ProX?
Joh. Luger - Reply
Same. I cant find any on the web.
Salleh Ahmed -
its very use full . thank ifixit.com
i have surface pro x
Yasin Rayan - Reply
hola buenas tardes tengo una surface pro x le tenia puesto una skin para protección en la parte trasera decidí quitarla al quitarla la jale y sentí que jale tan fuerte que se levanto un poco la parte trasera después de eso mi conexión 4G comenzó a fallar y ahorita no puedo conectarme al 4G. mi duda pude a ver roto algún componente que hiciera que dejara de funcionar mi 4G? saludos espero puedan apoyarme ya que Microsoft no me resuelve nada saludos.
Edgar Sarmiento - Reply
Hi, I have my surface pro X lost one of its chip to connect to the keyboard. Where can I get my surface Pro X repair in the United States. I am currently in Memphis, Tennessee.
Then Yanuth - Reply
Do you know any place where I can get the Surface X screen replaced? My daughter dropped her unit and it needs replaced.
Eugen Murariu - Reply
I have problems with a connector keyboard, it’s lose one of its tab. Can it be repair?
Yanuth Then - Reply
Hello, Can anybody supply me with contens of MX25U1635E, even for some reasonable fee? Or Guys in Ifixit while you have disassembled Surface Pro X can you create dump of MX25U1635E , programmer use only while chip is on the PCB, it is impossible to remove it without damaging, strong cement under chip. If you can do it, leave comment here or I have post on Badcaps forum in BIOS secion
Branislav Kolacny - Reply
So the battery can't be remove ? I have one that is block with a lost password UEFI/BOIS and after a lot of research the solution is to remove the battery of the headmother many minutes and restart the surface .... Do you think it's possible
Stephanie Ruel - Reply
This makes me so happy! I've been on the fence about the Surface Pros, but now that I have one, I love it. But I don't love how I can't repair it without fear of breaking the glass (not an issue, should I need to replace the screen).
Monique Adam - Reply
Don't know if this is the place to ask but, what type of strips are used in the pc cover? It looks kinda sponge like and grey.
June - Reply
Past 24 Hours: 10
Past 7 Days: 112
Past 30 Days: 492
All Time: 85,071
