This teardown is not a repair guide. To repair your Fitbit Charge HR, use our service manual.
    1. Fitbit Charge HR Teardown, Remove Screws: step 1, image 1 of 1
      • Take the 4 Screws out of the Sides you will need a T3 star Screw Driver
      Ask FixBot
    2. Fitbit Charge HR Teardown: step 2, image 1 of 2 Fitbit Charge HR Teardown: step 2, image 2 of 2
      • You Pry out the Main board you can see the Metal Hooks
      Ask FixBot
    3. Fitbit Charge HR Teardown: step 3, image 1 of 1
      • You can Then pull out the Screws from around the Screen
      Ask FixBot
Bradley Nelson
56 Reputation
1 Guide authored
8 Guide Comments
Can the battery be replaced?
Rick - Reply Share
Mine was just over a year old (barely out of warranty) when it died. The Fitbit folks were kind enough to replace it anyway once I expressed my displeasure. I'd haggle with them a bit before going the DIY route but I'm definitely keeping my old one for spare parts. Hopefully someone will point out an aftermarket battery source before I need to do that.
fragmasterflash - Reply Share
The screws in mine were Torx T-2, not T-3.
Jake McIvor - Reply Share
The button is stuck in my ChargeHR. I bought the T3 screwdriver and it is too big. Either the screws are T2 or my screwdriver is too much imprecise.
Anyone fixed a stuck button?
Anderson Maciel - Reply Share
it definitely not T3 must be T2
Marc Frederick - Reply Share
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 27
All Time: 24,712
