Video Overview
This teardown is not a repair guide. To repair your Amazon Fire TV Cube, use our service manual.
    Final Thoughts
    • The majority of the device is held together by standard Torx screws.
    • The device construction is simple and straightforward to disassemble.
    • Antenna cables are soldered to the heat sink and the connectors are hidden behind a plastic frame, The potential for ripping one of these cables is high if you are not careful during disassembly.
    • All the ports are soldered to the motherboard.
    Repairability Score
    7
    Repairability 7 out of 10
    (10 is easiest to repair)
3 Comments
So... Where's the teardown?
David Fischer - Reply
i believe something missing with this teardown……
Marlin Rinehart - Reply
8 microphones??!!
Christopher Delaney - Reply
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 80
All Time: 16,668
