My Problem
The screen was shattered, could barely see what was on the screen.
My Fix
Very well! A little tricky lifting out the tiny glued circuit board for the touch ID, but otherwise went smoothly. The instructions were very detailed.
My Advice
1: Make sure you put the screws back EXACTLY the way you took them out. They are all different lengths by only millimeters and putting one in the wrong place will fry the iPhone.
2: THE MOST IMPORTANT!,.. taking out the Touch ID Home Button, make sure to gently lift from under the ribbon cable on the connection side, do not try to lift it from any other place, you risk damage.
0 Comments
