P2 Pentalobe Screwdriver iPhone
  • P2 Pentalobe Screwdriver iPhone / iFixit - Made in Germany / New
  • P2 Pentalobe Screwdriver iPhone / Moody - Made in USA / New
$8.99
$8.99
We'll send a message when the product is back in stock.
Product Details
Features
Features
Use this precision P2 pentalobe screwdriver to open iPhone and Apple devices. The P2 driver is compatible with the 5-point star shaped pentalobe 5IPR security fasteners used on the bottom of iPhones. The driver is compatible with the security screws on the bottom of all models of iPhone since the iPhone 4: iPhone 4/4S, iPhone 5/5s/5c, iPhone 6/6 Plus/6s/6s Plus, iPhone SE, iPhone 7/7 Plus, and iPhone 8/8 Plus.
The iFixit P2 pentalobe screwdriver features a knurled grip and rubberized, ergonomic handle with swivel top. Made in Germany with uncompromising quality in manufacturing, this precision P2 pentalobe screwdriver is the last driver you'll ever need to buy. And to back that up, it's covered by iFixit's Lifetime Warranty.
Check the product option dropdown for the ESD-safe screwdriver made by Moody.
Repair Stories
User avatar
My Problem
Input via digitizer became intermittently erratic. I could scroll screen with finger above screen not touching. Pressing one area made phone act like I had pressed a different area. There was a light streak down screen. This problem was intermittent and would come and go while phone was just sit . . .
User avatar
My Problem
Battery was draining within 2 hours and % remaining was never accurate (at 100%) and then would die.
My Fix
Super simple! Make sure that you have that pentalobe (?) screw driver.
My Advice
My battery was taped in with double sided tape. And was very difficult to remove until I heated up the tape. I heated up a hot/ . . .
User avatar
My Problem
My wife dropped her iPhone 6 and it popped the screen out and dented the corner. I used the Pentalobe #2 bit to remove bottom of the screen so I could place it back in properly.
My Fix
Very well.
My Advice
NA
User avatar
My Problem
The screen start flashing when turn the phone on. Save money buying the tools and fixing it myself, plus the experience
My Fix
Perfectly
My Advice
Saw a video on you tube
User avatar
My Problem
My iPhone 5s could not go 12 hours without needing to be charged. And this was with very minor use.
My Fix
The repair is a little tedious, but with patience and care, it can be done without hurting the phone.
My Advice
The pulling part, when you pull the old battery adhesive strip off, be very slow and gentle, specia . . .
User avatar
My Problem
A friend took his iPhone 6Plus scuba diving with a not so waterproof case.
My Fix
Was able to get the battery out and replace it...sadly it did not charge. The tool kit is amazing...every tool you need to make it go smoothly. I had watched a video with a 10 year old showing me how to open the case with an 1 . . .
User avatar
My Problem
I water damaged my 6s.
My Fix
It went great!
My Advice
Getting the front sensors, camera, and earpiece is definitely hard, but not too hard. Watch out for that.
User avatar
My Problem
Back panel of iPhone was scratched, including across the area over the camera lens, making photo quality terrible
My Fix
Took less than a minute, super super easy
My Advice
Note that the back panel on the iPhone 4 slides up a little to unlatch, you don't pry it off, you slide it a little. Reverse the motion to put the . . .
User avatar
My Problem
screen cracked
My Fix
The repair was fairly easy- you do need a micro screwdriver (smaller than the smallest you can get at Lowes or HD- so, if you don't already have one, get one from ifixit, along with the P2 pentalobe driver. The screws are so tiny that I can't pick them up with my fingers. Must use tw . . .
User avatar
My Problem
Cracked display
My Fix
Instructions were clear and accurate! Finished in 15 minutes. Delivery came in 2 days after my order...3 days earlier than expected!
My Advice
I can see how reinstalling the display may put undue pressure on the tiny piece of glass under the home button. Be careful when snapping the assembly in . . .
Show more
