P2 Pentalobe Screwdriver iPhone
A staff favorite
$7.95
$7.95
We'll send a message when the product is back in stock.
Product Details
Features
Features
The essential tool for the iPhone hardware hacker.
  • Fits the tiny 5-point pentalobe screws found on the bottom of the iPhone 4, 4S, 5, 5s, 5c, 6, and 6 Plus.
  • Sturdy precision driver with a solid metal shaft, rubberized plastic handle, and spinning top.
  • Fixed driver makes a great complement to a 54 Bit Driver Kit to speed up your more frequent repairs.
  • Upgrade to pro for an ESD safe professional-grade driver.
Also available as part of the Pro Tech Screwdriver Set
Repair Stories
User avatar
User avatar
User avatar
My Problem
My iPhone 5s could not go 12 hours without needing to be charged. And this was with very minor use.
My Fix
The repair is a little tedious, but with patience and care, it can be done without hurting the phone.
My Advice
The pulling part, when you pull the old battery adhesive strip off, be very slow and gentle, specia . . .
User avatar
My Problem
A friend took his iPhone 6Plus scuba diving with a not so waterproof case.
My Fix
Was able to get the battery out and replace it...sadly it did not charge. The tool kit is amazing...every tool you need to make it go smoothly. I had watched a video with a 10 year old showing me how to open the case with an 1 . . .
User avatar
User avatar
My Problem
Back panel of iPhone was scratched, including across the area over the camera lens, making photo quality terrible
My Fix
Took less than a minute, super super easy
My Advice
Note that the back panel on the iPhone 4 slides up a little to unlatch, you don't pry it off, you slide it a little. Reverse the motion to put the . . .
User avatar
My Problem
screen cracked
My Fix
The repair was fairly easy- you do need a micro screwdriver (smaller than the smallest you can get at Lowes or HD- so, if you don't already have one, get one from ifixit, along with the P2 pentalobe driver. The screws are so tiny that I can't pick them up with my fingers. Must use tw . . .
User avatar
My Problem
Cracked display
My Fix
Instructions were clear and accurate! Finished in 15 minutes. Delivery came in 2 days after my order...3 days earlier than expected!
My Advice
I can see how reinstalling the display may put undue pressure on the tiny piece of glass under the home button. Be careful when snapping the assembly in . . .
User avatar
My Problem
I have a FIIO X5s High Def music player and the back had been pulled open by the magnetic stand that I was using to hold it to my cars dash. It has 2 small screws that hold the back plate in place. The screw drive that I received wass perfect for the job. I was able to replace the back plate and sec . . .
User avatar
Show more
