P5 Pentalobe Screwdriver Retina MacBook Pro and Air
  • P5 Pentalobe Screwdriver Retina MacBook Pro and Air / iFixit - Made in Germany / New
  • P5 Pentalobe Screwdriver Retina MacBook Pro and Air / Moody - Made in USA / New
$8.99
$8.99
We'll send a message when the product is back in stock.
Product Details
Features
Features
Use this precision P5 pentalobe screwdriver to open Retina MacBook and MacBook Air laptops. The P5 driver is compatible with the 5-point star shaped pentalobe 5IPR security fasteners used on the bottom of some Apple laptops.
The iFixit P5 pentalobe screwdriver features a knurled grip and rubberized, ergonomic handle with swivel top. Made in Germany with uncompromising quality in manufacturing, this precision P5 pentalobe screwdriver is the last driver you'll ever need to buy. And to back that up, it's covered by iFixit's Lifetime Warranty.
Repair Stories
User avatar
My Problem
battery was dying and had "service battery" alert in notifications panel
My Fix
Went well except that the cord for the new battery was incrementally too short. It was able to plug in barely and on a slight angle, Hopefully this will be okay long-term; my concern is having to periodically open the assembly a . . .
User avatar
My Problem
Needed more RAM memory to upgrade to High Sierra OS.
My Fix
Great.
My Advice
Make sure you hav the correct RAM memory because there are various types.
User avatar
My Problem
My MBP trackpad was broken. Needed the pentalobe screwdriver to open my laptop to replace the trackpad.
My Fix
Huge pain in the ass. On my model of macbook pro, you have to remove the batteries which are glued-in to get access to the track pad. I saw a guy on youtube use a metal scraper to do it, so I did t . . .
User avatar
My Problem
Battery for Mac Air was dead. Ordered P5 Pentalobe Screwdriver and a battery on Ebay. Followed the directions on IFIXIT, which were excellent.
My Fix
Everything went without a hitch. Thank you!
My Advice
Follow directions. Carefully unplug and reconnect battery.
User avatar
My Problem
After five years the battery had cycled hundreds of times and was showing a need for service...
My Fix
The swap was quick and easy... less than 20 minutes... great repair guide and product.
My Advice
ifixit.com should always be the first place you try.... great advice and solid products...
User avatar
My Problem
Original Logic Board had failed
My Fix
Repair went without a hitch.
My Advice
Follow the instructions!
User avatar
My Problem
Trackpad kept drawing squares
My Fix
Good.
My Advice
I used a T6 screwdriver instead of a T5 on step 10. Don't removed a metal plug that appears to be taped to the bottom underside of the trackpad.
User avatar
My Problem
My laptop stopped being able to hold a charge. Left more than a minute unplugged the system would shutdown.
My Fix
Easier than I expected. Strangely only 4 screws were holding the case, either the others fell out or were left out by apple repair in the past.
Now the laptop can remain operational while un . . .
User avatar
My Problem
My fan was making a weird noise. I didn't know if the fan motor was dying, or if some debris was the culprit. In either case, I needed to open up and have a look. Unfortunately, I didn't have the special pentalobe screwdrivers to open up my MacBook.
My Fix
My biggest problem was that I didn't even know whic . . .
User avatar
My Problem
My sister accidentally dropped her Macbook Pro Retina after owning for more than 4 years. The warranty had expired a long time ago and the people at the Mac store gave an estimate of at least $700. When my family told me about this, I told them that was ridiculous and to order a new display from ifi . . .
Show more
