Flush Macro Cutter Heavy Duty C.H.P. TRR-5000
  • Flush Macro Cutter Heavy Duty C.H.P. TRR-5000
$19.99
$19.99
We'll send a message when the product is back in stock.
Product Details
Description
Description
C.H.P pliers and cutters are made in Italy for industrial and professional applications.
MACRO CUTTER
• Strong 5mm thick, chamfered cutting tool
• Strongest cutter in the line
• Specially treated cutting edges enable the tool to cut steel wire up to 0.5mm diameter (24 AWG)
Due to the perfect joint between the high-quality ground faces of the two halves, it is possible to lengthen the life and maintain the functionality of the tool by adjusting the screw to eliminate the play accumulated between the two faces over a long period of time.
Steel: 5.0 mm
Cut: Chamfered
Max cut: 10 AWG
Center Screw: Yes
