Flathead 3/32" or 2.5 mm Screwdriver
$6.99
$6.99
We'll send a message when the product is back in stock.
Black Friday
Broken doesn't stand a chance.
Product Details
Features
Features
Use this precision flathead screwdriver for electronics repair and DIY projects. It's the most basic screwdriver you'll need in your toolkit to fix laptops, small home appliances, and electronics. The small, flat screwdriver blade is also known as the "slot", "common", or "standard" screwdriver.
The iFixit flathead screwdriver features a knurled grip and rubberized, ergonomic handle with swivel top. Made in Germany with uncompromising quality in manufacturing, this precision flathead screwdriver is the last driver you'll ever need to buy. And to back that up, it's covered by iFixit's Lifetime Warranty.
Check the product option dropdown for the ESD-safe screwdriver made by Moody.
Repair Stories
User avatar
My Problem
Wifi, Bluetooth and GPS weren't working properly
My Fix
After changing this part, everything works perfectly.
My Advice
It's easy when you follow ifixit instruction.
User avatar
My Problem
The phone is 3+ years old and the battery would die in 3 hours of continuous usage. It also wouldn't charge unless you bend the lightning cable into the dock connector at an angle and keep it that way which is (holy ####) extremely frustrating and damages the appliance.
My Fix
The repair itself went with a . . .
User avatar
My Problem
... is the Multi Tool Roll does not come in fashion colors. I would reorder as soon as I knew I could get a green one
My Fix
My Advice
... is the Multi Tool Roll does not come in fashion colors. I w . . .
User avatar
My Problem
no charge
My Fix
fantastic
My Advice
non ascoltare solo apple
User avatar
My Problem
Broken hard disk cable
My Fix
It took only 5 minutes. Easy, fast, secure and now it's working! Don't be shy to repair something by yourself. And I've saved money!
My Advice
First of all, practice, get familiar with your mac. Watch tutorials.
User avatar
My Problem
Power button was not working, and the battery was failing.
My Fix
It was ok. The battery was rather hard to peel out, but after that, the power button procedure was ok.
My Advice
The guide says to un-hinge the power button before the cable is detached from the back case. I found that I had to take the volume buttons . . .
User avatar
My Problem
My aunt forgot the take out of the pocket her iPhone 5S before putting the jeans in the washer machine.
My Fix
There was no sign of sulfate or sparks on the logic board pins. We need to change the Dock port and probably the Battery but I am waiting on her desicion to spend $80 and it may be work or not.
My Advice
Yo m . . .
User avatar
My Problem
The 1TB hard drive in my 2011 iMac started failing. Luckily I had everything backed up on externals. I was super excited to see that iFixit had a dual hard drive kit, so I ordered that plus a 500GB SSD for my boot drive and a 3TB HDD for bulk storage.
My Fix
The repair went amazingly well. A co-worker helpe . . .
User avatar
My Problem
Upon visiting the Apple store to complain about the useless power button that mysteriously stopped working on my iPhone, I was told that my only option was to purchase an expensive "out of warranty" replacement. Fortunately, after researching the problem, I chose to buy a repair kit from iFixit ins . . .
User avatar
My Problem
cant afford a new replacement phone
My Fix
repair went fine
My Advice
dont need to remove the battery
Show more
