Detailing Brush
  • Detailing Brush / Nylon
  • Detailing Brush / Brass
Detailing Brush
Brass bristles are great for solder prep, cleaning soldering tips, cleaning up damage from leaking batteries or corrosion from male or female connectors.
Brass bristles are softer then steel, and will clean metal nicely without removing any of the base material.
$2.99
$2.99
We'll send a message when the product is back in stock.
Product Details
Description
Description
No more worn out toothbrushes with bent bristles, these economic professional tools will do the job faster and better, fitting into more places, and don't require handle bending pressure to do a good job. These bristles are ready to scrub and clean with minimal effort.
Repair Stories
User avatar
My Problem
Water damage on a macbook pro.
There was a dime sized bit of corrosion on the logic board and it would not turn on.
My Fix
Pulled the back off, unhooked the battery, stogged the corroded bits with a really soft brush and alcohol. Let it dry, put it back together and it turned back on.
My Advice
Be brave...
User avatar
My Problem
I am just starting out in the repair business, I repair all sorts of electronics, mainly the repairs are either Mobile Devices, Laptops, Computers. IFIXIT.com has a lot of the tools that are required for repairing these devices.
My Fix
Repairs go a lot quicker with the right tools.
My Advice
Make sure you have the ri . . .
User avatar
My Problem
Bass from speakers just come out as muddled.
My Fix
Removed without much trouble.
My Advice
The original screws securing the sub-woofer strips quit easily. Pay attention when removing them. I had to discard one screw I stripped. Luckily I could remove them by forcing the screwdriver into the screw to create new indent . . .
User avatar
My Problem
Silly Tri-Tip screwdrivers, lucky ifixit came to the rescue!
My Fix
Excellently
My Advice
Make sure you order the right battery from Amazon, it's too bad that ifixit doesn't stock batteries for newer Macbook Pro's
User avatar
My Problem
Just needed some more tools for opening Apple Mac's, Getting out laptop screws that have had there heads destroyed and the magnetic project mat for the laptop screws.
My Fix
Always good
My Advice
By the right tools for the right job and it always easier.
Show more
