P6 Pentalobe Screwdriver 2009 15" MacBook Pro Battery
$7.95
Product code: IF145-070
Click Image To Zoom
$7.95
Product Overview
Access your battery and your right to repair.
  • Used to remove 5-pointed "Pentalobe" screws on the mid 2009 MacBook Pro 15" Unibody's battery.
  • Compatible with fasteners removable with Apple specialty tool 922-9101.
Also available as part of the Pro Tech Screwdriver Set
Please note: This is NOT the driver to open the 2012 Retina Display MacBook Pro or the MacBook Air, that driver can be found here: P5 Pentalobe Screwdriver Retina MacBook Pro and Air.
Compatibility
  • All Mid 2009 Unibody 15" MacBook Pros
Product Details
$7.95 iFixit
Condition:
New
Notes:
A staff favorite!
$11.95 USA
Condition:
New
Notes:
The nicest Macbook Pro battery driver available anywhere! Made in the USA with a lifetime warranty, this very nice driver will be the last one you have to buy. Features a reversible tip, with the pentalobe driver on both sides, so you have redundant reliability.
Anodized billet aluminum handle with swivel top.
Add to Cart
Compatibility
MacBook Pro 15" Unibody 2.53 GHz Mid 2009
2.53 GHz (Mid 2009)
MacBook Pro 15" Unibody Mid 2009
2.66 GHz (Mid 2009)
2.8 GHz (Mid 2009)
3.06 GHz (Mid 2009)
Stories
My Problem
I purchased a battery for a mid2009 MacBookPro 15" screen . tools were included. However, wrong size. iFixit stocked the size it required.
My Fix
Smooth
My Advice
The on line store where I purchased the battery from reimbursed me for the cost of the entire iFixit purchase; including S&H!
My Problem
The IMAC PRO 2009 model Battery was no longer charging though it was still working from the power cord .
I looked at all options including replacing the Mac
My Fix
After watching the video tips.. I remembered what i had to do.
It took me less than 10 minutes to change it ..half of that was chat ting to my friend:)
It was just too to easy to believe.
My Advice
Get onto the website and youtube that advise you on how to fix the problem.
you're battery may not be totally gone like mine ..but try the options.
if you know there are no options left other than discarding the mac
Go to IFIXIT Site and order a new battery.
They'll advise you on what you need and how to replace the battery.
It costs $138 for a new battery and little bit of time
By the way ..for Aussie's and maybe other countries it cost more due to the exchange rate $250 But It was definitely worth it.
Apple Tech's would cost more and so would a New mac.
The only pieces of advise is :you will need 2 x screwdrivers ..one for the casing which is a really tiny screwdriver.
and the one I purchased for the battery screws.
The other advise is "DO IT" ..Replace it yourself!
It was easiest thing I have done in years.
its working perfectly now!
My Problem
I needed to repair my trackpad, looking at some tutorial online to see if there is a way of fixing it, so I started unscrewing the bottom open up the laptop, then the trackpad is under the battery so needed to remove the battery 1st
Then looking at the battery I noticed it wasnt a regular shape and for a while already I got the OS X status that the battery can still work but probably need a replacement. And also taking out the screw next to where the battery is located notice the aluminium cover was pushed by it.
Then battery remove and before changing anything regarding the screw of the trackpad just opened the computer that was upside down to click on it and the %#*@ trackpad was clicking as how I remembered it.
So conclusion was that the battery that was swallowed was pushing on the trackpad, then looking at some of the comment under the tutorial that you guys had the same issue.
So solution was to replace the battery, and in 2 things in one trackpad working and I have a new battery life.
My Fix
Already did it a couple times for cleaning the computer, nothing much to say after the problem explanation, just took less than 10min to open up the computer and replace battery and then battery working now and trackpad also :)
My Advice
No advice in particular except that I know sometimes it can be long to read all comments under a tutorial but just take the time to do it, sometimes you'll see some people with same issue with a computer with 6yo+ than could same you time :)
My Problem
The old battery didn't have much life left in it, but that was actually the smaller problem. The battery had gotten to the point where it had swollen so much that it was pushing up on the bottom of the track pad made clicking impossible. I had to enable some of the multi-touch features just to be able to click and drag and drop!
My Fix
Very easy. Nothing was glued in this model, and the bottom screws are easy too remove. Too easy in fact, which is why I bought a screw set since 2/3s of my screws had fallen out and been lost. Good to have my bottom cover on securely and fresh loctite on the threads.
My Advice
The walk-through calls out the spudger, but you really don't need it to bend the sticker over the left battery screw back.
Also, a great time to clean your fans if you haven't done so in a while.
My Problem
Black screen when turning on computer.
My Fix
Good.
My Advice
Just to add how approx. how much thermal paste to use.
My Problem
Battery was bloated after using for 5years.
My Fix
Excellent! instructions were clear and it was easy to replace!
My Advice
When screwing
Anti- clockwise = unscrew.
vice versa.
My Problem
Battery would not charge
My Fix
It was pretty easy with the right tools and a guide. One screw is hidden and the guide showed where it is.
My Advice
Doesn't take very long; be careful not to lose any of the tiny screws.
My Problem
battery time was down to 15 min
My Fix
repair was done without any problems. Took about 10 min
My Advice
description is complete
My Problem
The old battery had swollen enough to push on the trackpad.
My Fix
The repair went exactly as advertised!
My Advice
Because the old battery was swollen, it pushed against the bottom case panel with enough force to throw the tiny screws some distance as I loosened them! If your old battery is swollen, take care to apply some pressure to the bottom panel and contain the screw you're removing until you've completely removed the screw.
My Problem
I noticed there were read/write errors and the hard drive had all ready been replaced.
My Fix
The replacement SATA cable did the trick.
My Advice
Careful removing the original cable from the second bracket, it's not difficult to do, just be patient with it.
