iMac Intel 27" (Mid 2010) Dual Hard Drive Kit
  • iMac Intel 27" (Mid 2010) Dual Hard Drive Kit / Upgrade Bundle
$27.99
$27.99
We'll send a message when the product is back in stock.
Product Details
Description
Description
Hack a second Hard Drive into your 27" Intel iMac.
  • This custom kit exploits an extra SATA port unused on the iMac logic board.
  • Use our easy to follow guide to do the job.
  • Mount your drive inside the case, out of sight completely.
  • The kit does not include a Hard Drive.
  • Intended for use with 2.5" hard drives or solid state drives.
Kit Contents
Kit Contents
Compatibility
iMac Intel 27" EMC 2390
2.8 GHz (Mid 2010)
2.93 GHz (Mid 2010)
3.2 GHz (Mid 2010)
3.6 GHz (Mid 2010)
Repair Stories
My Problem
Performance issue
My Fix
Sdd addee in imac 2011
My Advice
Not easy to find board connector
My Problem
I was having system overload errors using Logic, and both Disk Warrior reported that my HDD was failing.
My Fix
Very smooth! I took my time and it was much easier than I expected. The hardest part was getting all the little plugs out and routing the new wires. It is fun to look inside the machine! I added . . .
My Problem
I got the iMac at my Dad's university for free, but the hard drive was dead. I wanted to get it up and running, so I decided to replace the hard drive.
My Fix
It went smoothly, the only hitch I encountered was removing the bezel, which required some force and a flat head screwdriver.
My Advice
The only advice I have f . . .
My Problem
The old hard drive died..
My Fix
Only problem was the heat sensor plug which was different on the new hard drive.
My Advice
There is an App to take care of the fan....do not need the heat sensor....
My Problem
Your document is made for adding an additional SSD drive on a mid 2010 iMac i7. id 11.3
My Fix
Note:
1. There was one more screw, or 9 instead of 8 on the motherboard.
2. Sugestions: When you unscrew the screws on the motherboard, as sure to have inserted into the holes at the rear of the frame cable or USB . . .
My Problem
L'iMac n'avait pas de problème, c'était pour l'upgrader. L'installation d'un SSD supplémentaire dans Mac m'a permis de le configurer en mode Fusion Drive. Le SSD utilisé est le Samsung 840 Pro de 128Go.
Mon iMac 27 pouces de Mid 2010 a une seconde jeunesse!
My Fix
Très bien, le tuto est conforme aux . . .
Show more
