MacBook Unibody (A1278) Subwoofer and Right Speaker
  • MacBook Unibody (A1278) Subwoofer and Right Speaker
Condition: Used
$19.99
$19.99
We'll send a message when the product is back in stock.
Product Details
Description
Description
Replace a broken or damaged subwoofer and right speaker for your Model A1278 MacBook Unibody with this part. This assembly includes the subwoofer and right speakers with cables.
Compatibility
Repair Stories
Edward Wagner's Story Photo #1369776
My Problem
Yesterday, smoke rolled out of this aircraft cockpit printer as soon as the power came on. The power supply failed and the transformer belched smoke. The stench was incredible.
My Fix
The maintenance manual includes a service bulletin detailing the replacement of the old power supply with a newer, more reli . . .
My Problem
Battery went from lasting 9 hours to 2 hours. Can't say if new battery will last longer yet until it's had a chance to fully charge.
My Fix
Easy enough to take out screws and pry open the back. Gently removed old battery and slid in new one. I looked at a short video first, but it was more reassuring . . .
My Problem
I was given a Yashica Mat 124G camera that needed a viewfinder cleaning badly.
My Fix
The Moody JIS driver set were exactly what was needed to remove the viewfinders very tiny micro screws to access the internal mirror for cleaning. The tools worked perfectly and would not have been possible without the ri . . .
My Problem
Replace the hard drive for my iMac 21 inch
My Fix
Smooth without a problem following step by step guide I end replacing the hard drive after I made a clone version of the old hard drive to the new upgraded hybrid 2 T
My Advice
You have to have the right tool for the right job.
The only inconvenience is to find my . . .
My Problem
Screen was cracked
My Fix
Brilliant thanks to ifix it guide
My Advice
Not hard whatsoever as long as you have the tools and tech savvy experience
My Problem
Now I can fix all my iPhone, iPad and iPod easier than before and I will buy some more tools to make high qualities works, thank you!
My Fix
Everything Ok!
My Advice
Be careful with your device before it breaks.
My Problem
The device was still relatively useful and the repair isn't too hard.
My Fix
Quite easily - the hard part is getting the case apart.
My Advice
Use the metal thin tools to release the plastic bezel - the cable to the digitizer is super fragile so be careful removing the bezel after releasing it.
Show more
