Parts Mac MacBook Retina 12" 2017 Wi-Fi Boards
Store
Don't know your model? ID Your Mac
MacBook 12" Retina (Early 2016-2017) USB-C Port Assembly
Replace a damaged or corroded USB-C port and the flex cable that attaches it to the logic board in an early 2016 or 2017 model 12" Retina MacBook.
$29.99
MacBook 12" Retina (Early 2016-2017) IPD Flex Cable
This cable connects the trackpad assembly to the logic board in a 2016 or 2017 model 12" Retina MacBook.
$19.99
MacBook 12" Retina (Early 2015-2017) Display Cable
Replace the display assembly flex cable.
$19.99
MacBook 12" Retina (Early 2015-2017) Display Assembly / Premium / Dark Gray
Replace your cracked, dark, or dead-pixel infested MacBook Retina display assembly. This 2304x1440 LCD, 12" screen is complete with aluminum case and camera.
From $449.99
MacBook 12" Retina (Early 2015-2017) Lower Case Screw Set / Silver
Replace the color coordinated exterior screws that hold the lower case panel in place.
$14.99
MacBook 12" Retina (Early 2016-2017) Trackpad / Silver
Replace the "Force Touch" trackpad for a 2016 or 2017 model MacBook 12" Retina.
$69.99
MacBook 12" Retina (Early 2016-2017) Battery / New / Fix Kit
Replacement 5480 mAh battery for Early 2016 to 2017 Model MacBook 12" Retina laptop.
From $119.99
MacBook 12" Retina (Early 2016-2017) Upper Case with Keyboard / Silver / New
Replace a dented or scratched upper case or malfunctioning keyboard for your Early 2016 or 2017 12" MacBook with this part. This assembly includes the upper case aluminum...
From $127.99
MacBook 12" Retina (Early 2015-2017) Keyboard Flex Cable
This cable connects the keyboard to the trackpad assembly.
From $14.99
MacBook 12" Retina (Early 2016-2017) Lower Case Assembly / A-Stock / Gold
The lower case assembly includes the aluminum bottom case and the battery.
$89.99
Showing products 1 - 10 of 19
Device Info
Updated version of the 2016 Retina MacBook. Model A1534, EMC 3099. Now features faster Kaby Lake processors up to 1.4 GHz Core i7 with Turbo Boost up to 3.6 GHz and up to 50 percent faster SSD, and supports up to twice the memory.
