MacBook Pro 17" Unibody (Early/Mid 2009) MagSafe DC-In Board
  • MacBook Pro 17" Unibody (Early/Mid 2009) MagSafe DC-In Board
  • 360°
360
This used part may be missing the light gray plastic face. The plastic can be transferred from your existing part.
Condition: Used
$44.99
$44.99
We'll send a message when the product is back in stock.
Product Details
Description
Description
Is your laptop not charging correctly?
This part connects the wall adapter power to the logic board. A safe magnetic connection prevents damage to the laptop caused by tripping over the power cord. Identified by 820-2361-A printed on board.
Compatibility
2.66 GHz (Early 2009)
2.8 GHz (Mid 2009)
2.93 GHz (Early 2009)
3.06 GHz (Mid 2009)
Repair Stories
User avatar
My Problem
DC-in port was defective. The charging connector would get hot and make a soft high pitched electronic "squeal." Eventually the two outer prongs on my chargers would melt down to little nubs to the point where the computer wouldn't even charge anymore. I let the damage get so bad that my DC-in port . . .
User avatar
My Problem
My MagSafe dc in board was charred from using an old charger (possibly wrong voltage) and continued to work, but only if the charger sat at a specific angle.
My Fix
WARNING My 2011 MBP 17" uses a Torx T6 as well as a Phillips#00, that was not mentioned in the ifixit guide, but luckily I was able to g . . .
