MacBook Pro 17" (Model A1261) Right Fan
  • MacBook Pro 17" (Model A1261) Right Fan
$39.99
$39.99
We'll send a message when the product is back in stock.
Product Details
Description
Description
Replace a malfunctioning or noisy fan compatible with a Model A1261 17" MacBook Pro.
If your screen is facing you, this is the fan on the right side of the machine. Includes fan and surrounding metal bracket.
Looking for the Left Fan?
Compatibility
Compatibility
  • MacBook Pro 17" A1261 Early 2008 and Late 2008
Specifications
Specifications
Part #:
922-8396
Compatibility
Repair Stories
User avatar
My Problem
After many years, my beloved MacBook Pro 17 (early 2008 - A166X), was about to "byte" the dust (yes, pun intended). I had heard some intermittent noise occasionally, but it had always gone away. Now it was consistent, loud (annoyingly so), and starting to make the system overheat. (I verified this b . . .
User avatar
My Problem
The right fan in my MacBook Pro 17" was making an annoying whine. The fan was dying.
My Fix
Thanks to iFixIt and the great instructions on the website for replacing a right fan the repair went very well. I had a friend who works with computers help me. The instructions were very helpful for him.. It took ab . . .
User avatar
My Problem
After 7 years of constant use, right fan bearing was going bad making moaning/grinding noise
My Fix
Slicker than snot on a griddle - 20 min total from start to finish only because some of the tiny Phillips screws were reluctant to go back in.
My Advice
Nothing to add - between the part/spudge and online guides everyth . . .
User avatar
My Problem
The right fan on my MBP sounded like a chain-wielding demon hampster running on its torture wheel.
My Fix
20 minutes after the parts were delivered, the computer was up and going silently again. Ifixit's instructions were clear and easy to follow.
My Advice
Be careful with all the tape, especially the aluminum/copper . . .
User avatar
My Problem
The right fan had become very loud.
My Fix
I first tried to just clean the fan blades, as others on the web have noted. But the blades are fragile and I managed to break one off while cleaning. Even though I was being quite careful.
So I bought a new fan. I decided to replace both fans as both were dirty . . .
User avatar
My Problem
My MBP right cooling fan had been "talking" to me for years, soft ticks and growls. Then it began screeching solid and loud. The shaft was in critical orbit mode.
My Fix
The part arrived early the next day (all it takes is money) and I was up and running by 11:00 am. I followed the steps and photos, la . . .
User avatar
My Problem
Right fan started to make a grinding noise.
My Fix
The repair went very smooth.
start to finish time about 30mins.
My Advice
The hardest part is the plugin for the fan. It is a little goofy to install, press down, don't try to slide it in.
User avatar
My Problem
Noisy right fan ended up dead
My Fix
Quite easy. Took about half an hour. But the brand new Phillips #0 Screwdriver didn't last - the tip broke off although handled with care - made it difficult to reassemble the machine. A bit annoying.
My Advice
The photo of the macbookpro 17" model A1261 Fan shown in the iFixit Gui . . .
User avatar
My Problem
The right fan on my MacBook was running very loudly and had become almost unbearably noisy at full speed.
My Fix
I ordered the replacement fan and the tool kit that was on sale - one cannot have too many tools can one?
The repair went very smoothly - the guides provided online were very descriptive . . .
User avatar
My Problem
very noisy fan
My Fix
very good, it took me less than 1 hour without hurrying. First time I opened a laptop in my life so the instructions were very useful.
My Advice
make sure you know how to disconnect the cables to prevent damage: pull up/sideways.. etc.
Show more
