MacBook Pro 17" (Model A1261 Hi-Res) LCD LED Panel
  • MacBook Pro 17" (Model A1261 Hi-Res) LCD LED Panel
Glossy finish screen. LCD is new and in excellent condition.
$219.99
$219.99
We'll send a message when the product is back in stock.
Product Details
Description
Description
Replace your LCD!
Glossy and matte finish LCDs are interchangeable, you can install either type in your MacBook Pro 17", regardless of the original LCD panel type
IMPORTANT: This LCD is only compatible with MacBook Pro 17" laptops that are model A1261 and shipped with LED displays and a 1920x1200 resolution. Although visually identical, this part will not work in the Low-Res CCFL 1680x1050 Models. The LCD for the low-res model can be found here: MacBook Pro 17" (Model A1151/A1212/A1229/A1261) LCD Panel.
Compatibility
Repair Stories
User avatar
My Problem
LCD was bad on a Macbook Pro A1261, ordered new screen.
My Fix
Took everything apart only to realize I had ordered the wrong screen. Take note technicians, check your connectors on new parts before breaking everything down. And read everything about the part you are ordering carefully.
My Advice
iFixit team respond . . .
User avatar
My Problem
in quick succession I broke the LCD on the 17" Macbook Pro due to sloppy handling, and I shattered the glass front on my iPhone 5.
Both were not yet at the end of their life/usefulness so I decided to fix both myself.
My Fix
things went pretty well. Finished both repairs in about 3 hours (while watching . . .
User avatar
My Problem
My 1 year old son had smashed my MacBook Pro screen and it was damaged for more then a year. I inquired at the local Apple Store and was shocked to know that the LED display would cost me around 1000$, it was so expensive that I thought I would never be able to repair it, until ifixit stepped in my . . .
User avatar
My Problem
Broken LCD on my macbook pro
My Fix
Ordered part to fix. But it was damaged:( so i called got a replacement. Great CS by the way. Well.. I got ancy and started to take apart the laptop and found out that i ordered the wrong part.. Called back and the 1st replacement was already sent. So i ordered the right . . .
Show more
