MacBook Pro 17" (Non-Unibody) Display Components
Grab a toolkit for your MacBook Pro 17" (Non-Unibody) model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Choose your model of MacBook Pro 17" (Non-Unibody):
Parts that work with MacBook Pro 17" (Non-Unibody):
MacBook Pro 17" (Models A1151/A1212/A1229) Display Data Cable
Replace a damaged or malfunctioning cable connecting the LCD panel to the logic board.
MacBook Pro 17" (Model A1151/A1212) Display Inverter
Replace a malfunctioning inverter board in a 17" MacBook Pro. A bad inverter can cause a dead backlight.
MacBook Pro 17" (Model A1212) Clutch Cover
Replace a faulty, cracked or broken LCD hinge clutch cover on your MacBook Pro 17".
MacBook Pro 17" (Model A1212) Antenna Cover
Replace an Antenna Cover compatible with the A1212 model 17" MacBook Pro laptop. This part houses the AirPort antenna cable assembly within the clutch cover.
Device Info
The MacBook Pro 17" replaced the Aluminum 17" as Apple's pro machine and features Intel processors and a large widescreen display. The cases of the MacBook Pro 17" Models A1151, A1212, A1229, and A1261 are composed of aluminum, just like the PowerBook G4 before it, but the MacBook Pro 17" includes a built-in web camera called iSight, and a MagSafe power connector.
The most common repairs with the Non-Unibody model 17" MacBook Pro laptops are replacing a dead battery, replacing a malfunctioning fan, and upgrading the hard drive or RAM.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 17" repair guides for step-by-step instructions on how to make the fix.
