MacBook Pro 15" (Model A1211) Left I/O Board
  • MacBook Pro 15" (Model A1211) Left I/O Board
  • 360°
360
Condition: Used
$34.99
$34.99
We'll send a message when the product is back in stock.
Product Details
Description
Description
  • Replace a damaged or corroded I/O board for your model A1211 MacBook Pro 15" and fix problems with charging, audio, and data connections. This assembly includes the MagSafe power, USB, and audio ports.
  • Includes slots for internal Airport wireless card and PC Card ExpressCards.
Compatibility
Repair Stories
Omar Santiago's Story Photo #1333851
My Problem
I had to replace the battery since mine was not charging anymore and I was NOT going to pay Apple's $500 amount. They were charging me that much for the battery replacement and trackpad cleaning. I came back home purchased the 64 bit driver kit, spudger and tweezers. In total I spent about $100 incl . . .
My Problem
I wanted the magnets and the platters. I'm not repairing anything why are you asking me about that? If anything I was destroying stuff, not that the hard drives worked anyway.
My Fix
uh, I got some magnets? And some platters?
My Advice
no not really.
My Problem
VERY, VERY EASILY. (Oops! Have my caps lock on.) I've been using iFixit for year and years. Helped me replace the power inverter for the display on my old Dell 10 yrs ago (so simple and so inexpensive!), before I got fed up with Microsoft (track pad not working & someone at MS actually told me, from . . .
My Problem
The battery was swollen and the trackpad had been pushed up out of the chassis. The bottom of the laptop was bowed out.
My Fix
I purchased the iFixit Driver Kit to get the drivers I needed to take the back off and to remove the computer. I then installed the battery I bought from iFixit. My computer is work . . .
My Problem
Needed to destroy storage on old phone before it's sent to recycling
My Fix
The "Repair" as it is hasn't happened yet because when you open up the Moto G, everything is covered in metal panels. I wanted to drill into whatever was the storage area before sending the phone off to recycling so that nefarious p . . .
My Problem
The factory battery began to expand and was causing problems.
My Fix
Very easy and simple. Just needed the right screw driver bit.
My Advice
Nope.
My Problem
My Gamecube C-Stick was drifting in games.
My Fix
Will be quick
My Advice
With the proper driver I could unscrew the triangle screws holding together controller. I noticed that a new C-stick is needed. Now all I need to do is replace the C-stick with a similar stock item.
My Problem
This is what we do..
My Fix
as it should
My Advice
Never give up.
My Problem
After we moved into our new house, our PS3 would overheat within seconds of powering it on.
My Fix
After following the steps for the full teardown, I was able to see that the thermal paste needed to be replaced in two spots. After carefully removing the old paste and replacing, it powered on and worked like . . .
My Problem
I had to remove a large heatsink from my CPU to replace the CPU, hwoever Hyper 212 evos arte notorious for being less than steller with their X bracket mount despite otherwise being an awsome cooler. So I purchased the 64 peice driver set and it worked amazingly. Arrived a day later than expected bu . . .
Show more
