MacBook Pro 13" Unibody Mid 2009 Optical Drives
Grab a toolkit for your MacBook Pro 13" Unibody Mid 2009 model and bring your laptop back to life!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Parts that work with MacBook Pro 13" Unibody Mid 2009:
Unibody Laptop Dual Drive
Increase the storage space in your laptop by replacing the optical drive with a second hard drive or SSD.
MacBook Pro 13" Unibody 8x SATA SuperDrive (Used)
Replace a malfunctioning optical drive compatible in your 13" Unibody MacBook Pro. Model #UJ8A8, UJ898A, UJ868A. Part #661-5165, 661-5502, 661-5865.
SATA Optical Drive USB Cable
Connect an optical drive to your computer via USB with this part.
Unibody (Post-Early 2009) 8x SATA SuperDrive
Replace a broken or damaged SuperDrive for your Post-Early 2009 MacBook Unibody with this part. This part does not include the metal mounting bracket and orange ribbon ca...
Device Info
With the Mid 2009 model 13 inch MacBook Pro Unibody laptop, Apple brought back the Firewire 800 port, added an SD card slot, and increased the processor speed.
The most common repairs with the MacBook Pro 13" Unibody for Mid 2009 are replacing a dead battery or upgrading the hard drive or RAM. The MacBook Pro 13" Unibody (Mid 2009) Memory Maxxer RAM Upgrade Kit includes all the parts and tools you need to upgrade to 8 GB of RAM.
The MacBook Pro 13" Unibody for Mid 2009 requires a Tri-point Y0 Screwdriver to remove the battery. The battery kit includes all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 13" Unibody for Mid 2009 repair guides for step-by-step instructions on how to make the fix.
