MacBook Pro 13" Unibody Mid 2009 Case Components
Grab a toolkit for your MacBook Pro 13" Unibody Mid 2009 model and bring your laptop back to life!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Parts that work with MacBook Pro 13" Unibody Mid 2009:
MacBook Pro 13" Unibody (Mid 2009-Mid 2012) Trackpad
Replace a scratched or malfunctioning trackpad in your Mid 2009 to Mid 2012 13” Unibody MacBook Pro model A1278 laptop. Part #922-9063, 922-9525, 922-9773.
MacBook Pro 13" Unibody (Mid 2009-Mid 2010) Upper Case
Replace an upper case assembly compatible with the model A1278 Mid 2009 to Mid 2010 MacBook Pro 13" Unibody laptop. Includes the aluminum upper case frame, keyboard, batt...
MacBook Pro 13" Unibody Lower Case
Replace a scratched or bent lower case panel on your laptop.
MacBook Pro Unibody (Mid 2009-Mid 2012) Trackpad Mounting Screws
Replacement screws and springs for mounting the trackpad in the upper case assembly of your mid 2009 to mid 2012 13" and 15" MacBook Pro Unibody laptop.
Device Info
With the Mid 2009 model 13 inch MacBook Pro Unibody laptop, Apple brought back the Firewire 800 port, added an SD card slot, and increased the processor speed.
The most common repairs with the MacBook Pro 13" Unibody for Mid 2009 are replacing a dead battery or upgrading the hard drive or RAM. The MacBook Pro 13" Unibody (Mid 2009) Memory Maxxer RAM Upgrade Kit includes all the parts and tools you need to upgrade to 8 GB of RAM.
The MacBook Pro 13" Unibody for Mid 2009 requires a Tri-point Y0 Screwdriver to remove the battery. The battery kit includes all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 13" Unibody for Mid 2009 repair guides for step-by-step instructions on how to make the fix.
