MacBook Pro 13" Retina Late 2012 Heat Sinks
Grab a toolkit for your MacBook Pro 13" Retina Late 2012 model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Parts that work with MacBook Pro 13" Retina Late 2012:
MacBook Pro 13" Retina (Late 2012-Early 2013) Heat Sink
This part attaches to the processor and helps dissipate heat.
MacBook Pro 13" Retina Fan Ducts
Replace the elastic gaskets that direct the airflow from the fans to the heat sink compatible with the A1425 model Retina 13 inch MacBook Pro laptop. Part #923-0228.
Device Info
On October 23, 2012 Apple announced the new 13" MacBook Pro with Retina display. Similar to its larger cousin, the 15" MacBook Pro with Retina display introduced earlier in 2012, this new 13" MacBook Pro features a high resolution LED-backlit display. An integrated Intel HD Graphics 4000 graphics processor takes full advantage of the 2560-by-1600 resolution at 227 pixels per inch. The MBP Retina 13" has two USB 3 ports, an SDXC card slot, an HDMI port, and two ThunderBolt ports. It does not have Ethernet or Firewire ports, although adapters are available. The MagSafe Port has also been replaced with the MagSafe 2 port allowing for a thinner case design.
The most common repairs with the 13" Late 2012 model MacBook Pro with Retina Display laptops are replacing a dead battery or a damaged display assembly.
The battery in a MacBook Pro 13" Retina Late 2012 is adhered to the inside of the upper case. Our battery repair kits include the needed adhesive.
The MacBook Pro 13" Retina Display models require a P5 Pentalobe Screwdriver to remove the the lower case to begin any internal repairs. Our battery kits include all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 13" Retina Display Late 2012 repair guides for step-by-step instructions on how to make the fix.
The MacBook Pro 13" Retina Display Late 2012 earned a 2 out of 10 in iFixit's repairability assessment.
