MacBook Pro 13" Function Keys Mid 2017 Heat Sinks
Grab a toolkit for your MacBook Pro 13" Function Keys Mid 2017 model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Parts that work with MacBook Pro 13" Function Keys Mid 2017:
MacBook Pro 13" Retina (Function Keys, Late 2016-2017) Heat Sink
Replace a damaged heat sink in a 2016 or 2017 model 13" MacBook Pro with Retina Display and function keys.
MacBook Pro 13" Retina (Late 2016-2020) Heat Sink Brackets
Replace the two metal spring brackets that press the heat sink against the CPU in a 2016 to 2020 model 13" MacBook Pro with Retina Display.
Device Info
Released in June 2017 with Apple model number A1708 / EMC 3164, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar). This model packs an Intel Core i5 or i7 processor and two Thunderbolt 3 ports.
The most common repairs with the 13" 2017 model MacBook Pro with Retina Display and Function Keys laptops are replacing a dead battery or a damaged display assembly.
The battery in a MacBook Pro 13" Retina and Function Keys 2017 is adhered to the inside of the upper case. Our battery repair kits include the needed adhesive.
The MacBook Pro 13" Retina Display models require a P5 Pentalobe Screwdriver to remove the lower case to begin any internal repairs. Our battery kits include all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 13" Retina Display and Function Keys 2017 repair guides for step-by-step instructions on how to make the fix.
