MacBook 13" Unibody 2.4 GHz Case Components
Grab a toolkit for your MacBook 13" Unibody 2.4 GHz model and bring your laptop back to life!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Parts that work with MacBook 13" Unibody 2.4 GHz:
MacBook Unibody (A1278) Upper Case (Non-Backlit)
Replace an upper case and keyboard compatible with the non-backlit model A1278 MacBook Unibody 13 inch laptop. Part #661-4943, 661-5855.
MacBook Unibody (A1278) Upper Case (Backlit)
Replace an upper case assembly compatible with the Model A1278 MacBook Unibody Backlit laptop. Part #661-4944, 661-5856.
MacBook Unibody (A1278) Lower Case
Replace a scratched or dented lower case.
MacBook Unibody (A1278) Access Door
Replace a scratched or dented access door.
MacBook Unibody (A1278) Mid Wall
This part reinforces the center of the laptop's structure and secures the parts of the lower case.
MacBook Unibody (A1278) Trackpad
Replace a scratched or malfunctioning trackpad for your MacBook Unibody Model A1278 laptop. Part #922-9014.
Device Info
The 2.4 GHz model A1278 MacBook Unibody 13" has a backlit display.
This machine can be upgraded to 8GB of RAM using two PC3-8500 4 GB RAM chips. The hard drive can also be upgraded to a hefty, yet agile 500 GB 7200 RPM SATA hard drive.
Not sure what's wrong with your laptop? Check out our Troubleshooting Guide!
Select your category below or browse all compatible parts to find what you need to fix your laptop!
