Introduction
Replacing the logic board assembly gives you new flash memory as well as a new battery.
Insert the edge of an iPod opening tool into the gap between the outer case and the top bezel.
Pry the top bezel off the adhesive securing it to the display retainer.
Insert an iPod opening tool between the outer case and the display retainer.
Use the tool to slide the display assembly out of the case slightly.
Slide the display out of the Nano. It will move about .5" until the display data cable limits its travel.
With the display pulled out of the case as much as possible, gently press on the lower edge of the glass panel until it pops in slightly (~1 mm).
Use your thumbs on the lower edge of the glass panel to slide the glass down and into the case until the top edge pops up out of the case.
Use the edge of an iPod opening tool to separate the hold switch from the adhesive securing it to the top edge of the display.
While holding the light colored socket down with one finger, use the tip of a spudger to flip the ZIF cable lock up toward the bottom of the Nano.
Use an iPod opening tool to peel the display data cable off the thin metal plate attached to the display.
Insert an iPod opening tool between the bottom bezel and the dock connector.
Separate the bottom bezel from the adhesive securing it to the Nano and set it aside.
Use the flat end of a spudger to separate the battery from the adhesive securing it to the outer case.
Use the flat end of a spudger to push the logic board assembly and battery slightly out of the bottom of the Nano. Stop once it pops out a little bit.
Use the edge of an iPod opening tool to peel the click wheel ribbon cable and its ZIF socket off the dock connector.
Use the edge of an iPod opening tool to flip the ZIF cable lock up toward the headphone jack.
Use a pair of tweezers to slide the click wheel ribbon cable out of its socket.
Peel back the cable on both ends!
Pull the logic board assembly out of the outer case, minding the hold switch and click wheel cables that may get caught.
