Introduction
Prereq-only for detaching the display assembly.
Tool used on this step:Magnetic Project Mat$19.95
Remove three 1.2 mm Y000 screws securing the battery connector cover bracket.
Remove the bracket.
Use the point of a spudger to pry the battery connector straight up out of its socket.
Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
Remove the two 1.2 mm Y000 screws securing the display connector bracket.
Remove the bracket.
Use the tip of a spudger to pry up and disconnect the digitizer cable.
Remove the five screws securing the logic board connector bracket to the rear case:
Three 1.2 mm Y000 screws
One 1.5 mm Phillips screw
One 1.3 mm Phillips screw
Remove the bracket.
Use the tip of a spudger to pry the front sensor assembly connector up from its socket.
