iPhone Air Screen Removal
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. iPhone Air Screen Removal, Cracked glass preparation: step 1, image 1 of 1
      • Glass shards can complicate disassembly—or worse, cause injury. If your phone has a cracked screen, follow this step.
      • Apply strips of packing tape to the cracked glass until the whole screen is covered—this will help keep the glass contained and allow the suction cup to stick to the screen.
      • Make sure there's a single strip (not overlapping) of tape across the bottom edge, big enough for a suction cup to fit on.
      • Only cover the glass itself—don't stick any tape to the frame.
      • Consider wearing safety glasses to protect your eyes from any glass shaken free during the repair.
      Ask FixBot
    2. iPhone Air Screen Removal, Remove the pentalobe screws: step 2, image 1 of 1
      • Use a P2 pentalobe driver to remove the two 4.9 mm-long screws on either side of the USB-C port.
      Ask FixBot
    3. iPhone Air Screen Removal, Heat the bottom edge: step 3, image 1 of 1
      • Use a hair dryer or heat gun to heat the bottom edge of the screen until it's slightly too hot to touch.
      • Improper use of a heat gun can destroy the display and/or battery—follow the linked instructions carefully.
      Ask FixBot
    4. iPhone Air Screen Removal, Insert an opening pick: step 4, image 1 of 3 iPhone Air Screen Removal, Insert an opening pick: step 4, image 2 of 3 iPhone Air Screen Removal, Insert an opening pick: step 4, image 3 of 3
      • Apply a suction handle to the bottom edge of the screen.
      • Pull up on the suction handle with strong, steady force to create a gap between the screen and the frame.
      • If you can't create a gap, apply more heat to the edge and try again.
      • Insert the tip of an opening pick into the gap.
      Ask FixBot
    5. iPhone Air Screen Removal, Screen information: step 5, image 1 of 1
      • As you slice the adhesive securing the screen in the following steps, don't insert your pick deeper than 3 mm to avoid damaging the following areas:
      • Two delicate cables connecting the screen to the iPhone—one just above the Action button and the other about halfway along the left edge of the iPhone
      • Multiple spring contacts around the perimeter of the iPhone
      • There are multiple clips around the iPhone. You'll hear and feel these release as you slide past them.
      • Since you can't disconnect the battery during this repair, make sure your phone stays powered down, don't use metal prying tools, and be careful not to touch exposed contacts.
      Ask FixBot
    6. iPhone Air Screen Removal, Slice the bottom edge adhesive: step 6, image 1 of 3 iPhone Air Screen Removal, Slice the bottom edge adhesive: step 6, image 2 of 3 iPhone Air Screen Removal, Slice the bottom edge adhesive: step 6, image 3 of 3
      • Slide the opening pick along the bottom edge to release the adhesive.
      • If the adhesive feels difficult to slice, reheat the edge for a minute.
      • Leave the opening pick in the bottom left corner to prevent the adhesive from resealing.
      Ask FixBot
    7. iPhone Air Screen Removal, Heat the left edge: step 7, image 1 of 1
      • Use a hair dryer or heat gun to heat the left edge of the screen until it's hot to the touch.
      Ask FixBot
    8. iPhone Air Screen Removal, Separate the left edge adhesive: step 8, image 1 of 3 iPhone Air Screen Removal, Separate the left edge adhesive: step 8, image 2 of 3 iPhone Air Screen Removal, Separate the left edge adhesive: step 8, image 3 of 3
      • Don't insert your pick deeper than 3 mm to avoid damaging the ribbon cables.
      • Insert a second opening pick in the bottom left corner, close to the existing pick.
      • Slide the opening pick along the left edge of the screen to separate the adhesive and release the metal clip.
      • You'll hear and feel the metal clip release as you pass it.
      • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
      Ask FixBot
    9. iPhone Air Screen Removal, Separate the remaining adhesives: step 9, image 1 of 3 iPhone Air Screen Removal, Separate the remaining adhesives: step 9, image 2 of 3 iPhone Air Screen Removal, Separate the remaining adhesives: step 9, image 3 of 3
      • Repeat the heating and sliding procedure along the remaining screen edges to separate the adhesive and release the clips.
      Ask FixBot
    10. iPhone Air Screen Removal, Lift open the screen: step 10, image 1 of 3 iPhone Air Screen Removal, Lift open the screen: step 10, image 2 of 3 iPhone Air Screen Removal, Lift open the screen: step 10, image 3 of 3
      • At this point, the screen should be free from the frame. If the screen feels stuck, go back around the perimeter with your pick and separate missed sections of adhesive or stuck clips.
      • Carefully lift the screen and swing it over the left edge of the iPhone.
      • Prop the screen up with a small, sturdy object.
      Ask FixBot
    11. iPhone Air Screen Removal, Protect the front cameras: step 11, image 1 of 2 iPhone Air Screen Removal, Protect the front cameras: step 11, image 2 of 2
      • We recommend using polyimide (aka kapton) tape to keep the front cameras clean. You may skip this step, but be extra careful not to touch the cameras.
      • Install a strip of polyimide tape over the front camera assembly by pressing the tape down on either side of it. Don't press down on the assembly itself.
      Ask FixBot
    12. iPhone Air Screen Removal, Remove the connector cover: step 12, image 1 of 1
      • Use a tri-point Y000 driver to remove the 1.1 mm‑long screw securing the front sensor and display connector cover.
      Ask FixBot
    13. iPhone Air Screen Removal: step 13, image 1 of 3 iPhone Air Screen Removal: step 13, image 2 of 3 iPhone Air Screen Removal: step 13, image 3 of 3
      • Use tweezers or your fingers to lift the front sensor cover to a 45-degree angle and remove it.
      • During reassembly, insert each cover at a 45-degree angle to re-engage the hook before laying it flat against the press connector.
      Ask FixBot
    14. iPhone Air Screen Removal, Disconnect the screen: step 14, image 1 of 3 iPhone Air Screen Removal, Disconnect the screen: step 14, image 2 of 3 iPhone Air Screen Removal, Disconnect the screen: step 14, image 3 of 3
      • Use the tip of a spudger to pry up and disconnect the front sensor and screen press connectors.
      • During reassembly, align each connector carefully over its socket and press down with your fingertip or flat end of a spudger—first on one side, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
      Ask FixBot
    15. iPhone Air Screen Removal, Remove the screen: step 15, image 1 of 1
      • Remove the screen.
      • Follow this guide to reapply adhesive and install the new screen.
      • Be careful not to damage any of the spring contacts as you clean the frame.
      Ask FixBot
Finish Line
Nick Schultz
65,446 Reputation
343 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 136
