Tool used on this step:VoltClip$10.95
Plug the VoltClip's barrel connector into the USB-C elbow.
Use a clean fingernail or an opening pick to peel up one of the silver tabs on the battery.
Attach the red alligator clip to the lifted silver tab on the battery.
Attach the black alligator clip to the grounding screw located on the left side of the bottom edge.
Make sure the red alligator clip is secured. If the black alligator clip pops off its screw, disconnect the USB-C cable, reseat the clip, and try again.
Connect the USB‑C elbow to a power source (via a USB‑C cable) and wait 90 seconds for the adhesive to loosen.
Disconnect the USB-C cable from the elbow, then disconnect the alligator clips.
Repeat this procedure on the other silver tab to loosen the second adhesive strip.
Apply a suction handle to the center of the battery and lift it out with slow, steady force to remove it.
