iPhone 7 Speaker Assembly Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPhone 7 Speaker Assembly Replacement, Speaker Assembly: step 1, image 1 of 1
    • Remove the Phillips screw securing the Wi-Fi diversity antenna to the rear case:
    • One 3.2 mm screw
  2. iPhone 7 Speaker Assembly Replacement: step 2, image 1 of 1
    • Remove the following three Phillips screws securing the speaker to the rear case:
    • Two 1.3 mm screws
    • One 2.0 mm screw
  3. iPhone 7 Speaker Assembly Replacement: step 3, image 1 of 3 iPhone 7 Speaker Assembly Replacement: step 3, image 2 of 3 iPhone 7 Speaker Assembly Replacement: step 3, image 3 of 3
    • Use the point of a spudger to lift the two antenna cable connectors up off of the sockets on the logic board.
  4. iPhone 7 Speaker Assembly Replacement: step 4, image 1 of 2 iPhone 7 Speaker Assembly Replacement: step 4, image 2 of 2
    • Use tweezers to derout the antenna cables from their bracket on the logic board.
  5. iPhone 7 Speaker Assembly Replacement: step 5, image 1 of 2 iPhone 7 Speaker Assembly Replacement: step 5, image 2 of 2
    • Use tweezers to remove the antenna cables from the clip on the speaker.
    • Make sure to grasp the cable near the clip in order to avoid damaging the cable.
  6. iPhone 7 Speaker Assembly Replacement: step 6, image 1 of 2 iPhone 7 Speaker Assembly Replacement: step 6, image 2 of 2
    • Use the tip of a spudger to slide the speaker assembly towards the logic board and off of the rear case.
  7. iPhone 7 Speaker Assembly Replacement: step 7, image 1 of 1
    • Remove the speaker.
Scott Havard
49,702 Reputation
31 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 297
