iPhone 7 Speaker Assembly Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. iPhone 7 Speaker Assembly Replacement, Speaker Assembly: step 1, image 1 of 1
      • Remove the Phillips screw securing the Wi-Fi diversity antenna to the rear case:
      • One 3.2 mm screw
      Ask FixBot
    2. iPhone 7 Speaker Assembly Replacement: step 2, image 1 of 1
      • Remove the following three Phillips screws securing the speaker to the rear case:
      • Two 1.3 mm screws
      • One 2.0 mm screw
      Ask FixBot
    3. iPhone 7 Speaker Assembly Replacement: step 3, image 1 of 3 iPhone 7 Speaker Assembly Replacement: step 3, image 2 of 3 iPhone 7 Speaker Assembly Replacement: step 3, image 3 of 3
      • Use the point of a spudger to lift the two antenna cable connectors up off of the sockets on the logic board.
      Ask FixBot
    4. iPhone 7 Speaker Assembly Replacement: step 4, image 1 of 2 iPhone 7 Speaker Assembly Replacement: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Use tweezers to derout the antenna cables from their bracket on the logic board.
      Ask FixBot
    5. iPhone 7 Speaker Assembly Replacement: step 5, image 1 of 2 iPhone 7 Speaker Assembly Replacement: step 5, image 2 of 2
      • Use tweezers to remove the antenna cables from the clip on the speaker.
      • Make sure to grasp the cable near the clip in order to avoid damaging the cable.
      Ask FixBot
    6. iPhone 7 Speaker Assembly Replacement: step 6, image 1 of 2 iPhone 7 Speaker Assembly Replacement: step 6, image 2 of 2
      • Use the tip of a spudger to slide the speaker assembly towards the logic board and off of the rear case.
      Ask FixBot
    7. iPhone 7 Speaker Assembly Replacement: step 7, image 1 of 1
      • Remove the speaker.
      Ask FixBot
Scott Havard
51,365 Reputation
31 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 18
All Time: 675
