VTech InnoTab 2S Headphone Jack Replacement
    1. VTech InnoTab 2S Headphone Jack Replacement, Back Panel: step 1, image 1 of 1
      • Turn your device to where the back panel is facing you.
      Ask FixBot
    2. VTech InnoTab 2S Headphone Jack Replacement: step 2, image 1 of 2 VTech InnoTab 2S Headphone Jack Replacement: step 2, image 2 of 2
      • Lift the Leg all the way up and twist the bottom to remove.
      • Once the bottom part pops out the whole leg should just come off.
      • Remove any game cartridge from the device.
      Ask FixBot
    3. VTech InnoTab 2S Headphone Jack Replacement: step 3, image 1 of 3 VTech InnoTab 2S Headphone Jack Replacement: step 3, image 2 of 3 VTech InnoTab 2S Headphone Jack Replacement: step 3, image 3 of 3
      • Remove all of the plastic tabs on the device. These are covering screws that will need to be removed.
      • These covers are made of hard plastic so they may be difficult to remove.
      • There is a special tab in the cartridge cover that is made of rubber, make sure to not break this tab.
      Ask FixBot
    4. VTech InnoTab 2S Headphone Jack Replacement: step 4, image 1 of 2 VTech InnoTab 2S Headphone Jack Replacement: step 4, image 2 of 2
      • Remove all nine screws from the back of the device using a J0 bit.
      • Remove the small battery.
      Ask FixBot
    5. VTech InnoTab 2S Headphone Jack Replacement: step 5, image 1 of 2 VTech InnoTab 2S Headphone Jack Replacement: step 5, image 2 of 2
      • Using a plastic opening tool, detach the backplate from the front piece.
      • Do not use excessive force. Double check that you removed all the screws if the panel is not coming off easily.
      • Once the backplate has been removed, you will have access to the circuit board.
      Ask FixBot
    1. VTech InnoTab 2S Headphone Jack Replacement, Motherboard: step 6, image 1 of 1
      • First begin by removing the three cross-head screws using a J0 bit.
      Ask FixBot
    2. VTech InnoTab 2S Headphone Jack Replacement: step 7, image 1 of 1
      • First remove the ribbon cables. There are two highlighted by the red squares
      • Do not apply too much pressure and make sure that the black plastic tabs are fully open before you pull the cable out.
      Ask FixBot
    3. VTech InnoTab 2S Headphone Jack Replacement: step 8, image 1 of 1
      • Remove the camera from the assembly and put is a safe place so that it will not get damaged.
      Ask FixBot
    4. VTech InnoTab 2S Headphone Jack Replacement: step 9, image 1 of 1
      • Remove the board from the main assembly.
      • Be careful not to pull too hard so that the cables aren't broken.
      Ask FixBot
    5. VTech InnoTab 2S Headphone Jack Replacement: step 10, image 1 of 1
      • De-solder the points shown to fully remove the cables and free the board.
      • A soldering guide offered by IFIXIT can be found here Soldering Skills.
      Ask FixBot
    1. VTech InnoTab 2S Headphone Jack Replacement, Headphone Jack: step 11, image 1 of 1
      • First use the solderer tool to desolder the two points boxed in red on the image.
      Ask FixBot
    2. VTech InnoTab 2S Headphone Jack Replacement: step 12, image 1 of 1
      Tool used on this step:
      Buy
      • Flip over the circuit board.
      • Using the metal tweezers, firmly grasp the headphone jack on either side and pull up to remove.
      Ask FixBot
Esthevan Romeiro
261 Reputation
4 Guides authored
USF Tampa, Team 5-1, Lacy Fall 2016 Member of USF Tampa, Team 5-1, Lacy Fall 2016
USFT-LACY-F16S5G1
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 42
All Time: 497
