Introduction
Prereq only for battery removal when replacing the rear case.
Use a pair of tweezers with blunt tips to peel back one of the adhesive strips on the lower edge of the battery.
Use a pair of tweezers with blunt tips to peel back the other adhesive strip on the lower edge of the battery.
Slowly pull one battery adhesive tab away from the battery, toward the bottom of the iPhone.
Pull steadily, maintaining constant tension on the strip until it slips out from between the battery and the rear case. For best results, pull the strip at a 60ยบ angle or less.
Repeat the previous step for the second strip.
If you removed both adhesive strips successfully, skip the next step.
Otherwise, if either of the adhesive strips broke off underneath the battery and could not be retrieved, continue with the next step below.
Prepare an iOpener and apply it to the back of the rear case, directly over the battery. Alternatively, you can apply heat using a heat gun or hair dryer.
After about a minute, remove the iOpener, flip the phone over and use a plastic card to break up any remaining adhesive behind the battery.
