iPhone 7 Opening Procedure
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPhone 7 Opening Procedure, Pentalobe Screws: step 1, image 1 of 1
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm pentalobe screws on the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. iPhone 7 Opening Procedure, iPhone 7 Opening Procedure: step 2, image 1 of 1
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
  3. iPhone 7 Opening Procedure: step 3, image 1 of 2 iPhone 7 Opening Procedure: step 3, image 2 of 2
    • Attach a suction cup to the lower half of the display assembly, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
  4. iPhone 7 Opening Procedure: step 4, image 1 of 3 iPhone 7 Opening Procedure: step 4, image 2 of 3 iPhone 7 Opening Procedure: step 4, image 3 of 3
    • Pull up on the suction cup to create a small gap between the display assembly and the rear case.
    • Insert the flat end of a spudger into the gap.
    • The watertight adhesive holding the display in place is very strong, and creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, rock the screen up and down to weaken the adhesive until you can fit a spudger inside.
  5. iPhone 7 Opening Procedure: step 5, image 1 of 3 iPhone 7 Opening Procedure: step 5, image 2 of 3 iPhone 7 Opening Procedure: step 5, image 3 of 3
    • Slide the spudger to the left along the lower edge of the iPhone.
    • Twist the spudger to widen the gap between the display and rear case.
  6. iPhone 7 Opening Procedure: step 6, image 1 of 3 iPhone 7 Opening Procedure: step 6, image 2 of 3 iPhone 7 Opening Procedure: step 6, image 3 of 3
    • Slide the spudger up the left side of the iPhone, starting at the lower edge and moving towards the volume control buttons and silent switch.
    • Do not pry along the top edge of the phone, you risk damaging the plastic clips securing the display.
  7. iPhone 7 Opening Procedure: step 7, image 1 of 3 iPhone 7 Opening Procedure: step 7, image 2 of 3 iPhone 7 Opening Procedure: step 7, image 3 of 3
    • Insert the flat edge of a spudger into the bottom right corner of the device.
    • Twist the spudger to widen the gap between the display assembly and the rear case.
    • Slide the flat end of the spudger up the right side of the phone to break up the adhesive holding the display in place.
    • Do not insert the spudger further than the adhesive to avoid damaging delicate ribbon cables along the right edge.
  8. iPhone 7 Opening Procedure: step 8, image 1 of 2 iPhone 7 Opening Procedure: step 8, image 2 of 2
    • Pull up on the suction cup to lift up the display and open the iPhone.
    • Do not raise the display more than 10ยบ as there are ribbon cables along the right edge of the device connecting the display to the logic board.
  9. iPhone 7 Opening Procedure: step 9, image 1 of 1
    • Pull up on the small nub on the suction cup to remove it from the front panel.
  10. iPhone 7 Opening Procedure: step 10, image 1 of 2 iPhone 7 Opening Procedure: step 10, image 2 of 2
    • Slide an opening pick along the top edge of the iPhone, between the rear case and front panel, to break up the remaining adhesive holding the screen in place.
    • Be careful not to damage the plastic clips on the top edge of the phone.
  11. iPhone 7 Opening Procedure: step 11, image 1 of 3 iPhone 7 Opening Procedure: step 11, image 2 of 3 iPhone 7 Opening Procedure: step 11, image 3 of 3
    • Pull the display assembly slightly away from the top edge of the phone to disengage the clips holding it to the rear case.
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
Evan Noronha
223,594 Reputation
168 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 1,181
