iPhone 6s Display Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. iPhone 6s Display Replacement, Battery Connection: step 1, image 1 of 1
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm Pentalobe screws surrounding the Lightning connector.
  2. iPhone 6s Display Replacement: step 2, image 1 of 1
    Tool used on this step:
    iSclack
    $24.99
    Buy
    • If you don't have an iSclack, use a single suction cup to lift the front panel:
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is pressed securely onto the screen to get a tight seal.
  3. iPhone 6s Display Replacement: step 3, image 1 of 3 iPhone 6s Display Replacement: step 3, image 2 of 3 iPhone 6s Display Replacement: step 3, image 3 of 3
    • There is a notch on the underside of the display just above the headphone jack that is the safest place to begin prying the phone open.
    • Pull up on the suction cup to slightly separate the front panel assembly from the rear case.
    • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices and is held down with adhesive.
    • Once a small gap has been opened, insert the flat end of a spudger above the headphone jack.
  4. iPhone 6s Display Replacement: step 4, image 1 of 2 iPhone 6s Display Replacement: step 4, image 2 of 2
    • Twist the spudger to open the gap more and break it free from the adhesive.
    • Keep pulling up on the suction cup while twisting the spudger.
  5. iPhone 6s Display Replacement: step 5, image 1 of 2 iPhone 6s Display Replacement: step 5, image 2 of 2
    • Use the edge of a spudger to slice through the adhesive on either side of the phone.
  6. iPhone 6s Display Replacement: step 6, image 1 of 2 iPhone 6s Display Replacement: step 6, image 2 of 2
  7. iPhone 6s Display Replacement: step 7, image 1 of 3 iPhone 6s Display Replacement: step 7, image 2 of 3 iPhone 6s Display Replacement: step 7, image 3 of 3
    • Use the suction cup to open the display, breaking the last of the adhesive.
    • Don't open the display more than 90 degrees, as it is still connected at the top by three cables that may break if stretched.
  8. iPhone 6s Display Replacement: step 8, image 1 of 1
    • Lean the display against something to keep it propped up while you're working on the phone.
  9. iPhone 6s Display Replacement: step 9, image 1 of 1
    • Remove the following screws from the battery connector bracket:
    • One 3.0 mm Phillips #00 screw
    • One 2.3 mm Phillips #00 screw
  10. iPhone 6s Display Replacement: step 10, image 1 of 1
    • Remove the metal battery connector bracket from the iPhone.
  11. iPhone 6s Display Replacement: step 11, image 1 of 3 iPhone 6s Display Replacement: step 11, image 2 of 3 iPhone 6s Display Replacement: step 11, image 3 of 3
    • Use the flat end of a spudger to disconnect the battery connector from the logic board.
    • Push the connector to the side to ensure it doesn't accidentally make contact and power on the phone while you're working on it.
  12. iPhone 6s Display Replacement, Display: step 12, image 1 of 1
    • While holding the front panel open at about a 90ยบ angle, remove the following screws securing the front panel assembly cable bracket:
    • Three 1.3 mm Phillips #00 screws
    • Don't lose track of this screw! It's very important that the one 3.0 mm screw goes in the top-right corner of the plate. Anywhere else may cause damage to the logic board.
  13. iPhone 6s Display Replacement: step 13, image 1 of 1
    • Remove the front panel assembly cable bracket from the logic board.
  14. iPhone 6s Display Replacement: step 14, image 1 of 3 iPhone 6s Display Replacement: step 14, image 2 of 3 iPhone 6s Display Replacement: step 14, image 3 of 3
    • In the next three steps, take care to pry up only on the cable connectors, and not on their sockets on the logic board.
    • Use the flat end of a spudger to disconnect the front-facing camera and sensor cable connector.
  15. iPhone 6s Display Replacement: step 15, image 1 of 3 iPhone 6s Display Replacement: step 15, image 2 of 3 iPhone 6s Display Replacement: step 15, image 3 of 3
    • Use the flat end of a spudger to disconnect the display data cable connector.
    • When reassembling your phone, the display data cable may pop off its connector. This can result in white lines or a blank screen when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery connector.
  16. iPhone 6s Display Replacement: step 16, image 1 of 2 iPhone 6s Display Replacement: step 16, image 2 of 2
    • Finally, use the flat end of a spudger to disconnect the digitizer cable connector.
  17. iPhone 6s Display Replacement: step 17, image 1 of 2 iPhone 6s Display Replacement: step 17, image 2 of 2
    • Remove the display assembly from the rear case.
Sam Goldheart
465,854 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
135 Members
17,198 Guides authored
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 16
All Time: 185,386
