Introduction
Use this guide to replace the battery in an iPhone 6s.
Remove the two 3.4 mm Pentalobe screws surrounding the Lightning connector.
Pull up on the suction cup to slightly separate the front panel assembly from the rear case.
Once a small gap has been opened, insert the flat end of a spudger above the headphone jack.
Remove the following screws from the battery connector bracket:
One 3.0 mm Phillips #00 screw
One 2.3 mm Phillips #00 screw
Use the flat end of a spudger to disconnect the battery connector from the logic board.
Push the connector to the side to ensure it doesn't accidentally make contact and power on the phone while you're working on it.
Use tweezers to peel up the edges of the two adhesive strips at the bottom of the battery.
Grab the ends of the two adhesive strips and hold them together. Try to keep the strips flat and wide.
Slowly and gently pull the two strips up and away from the phone.
The strips will stretch to many times the length of the battery—keep pulling until they come out from between the battery and the rear case.
