iPhone 6s Battery Connection
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPhone 6s Battery Connection, Battery Connection: step 1, image 1 of 1
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm Pentalobe screws surrounding the Lightning connector.
  2. iPhone 6s Battery Connection: step 2, image 1 of 1
    Tool used on this step:
    iSclack
    $24.99
    Buy
    • If you don't have an iSclack, use a single suction cup to lift the front panel:
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is pressed securely onto the screen to get a tight seal.
  3. iPhone 6s Battery Connection: step 3, image 1 of 3 iPhone 6s Battery Connection: step 3, image 2 of 3 iPhone 6s Battery Connection: step 3, image 3 of 3
    • There is a notch on the underside of the display just above the headphone jack that is the safest place to begin prying the phone open.
    • Pull up on the suction cup to slightly separate the front panel assembly from the rear case.
    • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices and is held down with adhesive.
    • Once a small gap has been opened, insert the flat end of a spudger above the headphone jack.
  4. iPhone 6s Battery Connection: step 4, image 1 of 2 iPhone 6s Battery Connection: step 4, image 2 of 2
    • Twist the spudger to open the gap more and break it free from the adhesive.
    • Keep pulling up on the suction cup while twisting the spudger.
  5. iPhone 6s Battery Connection: step 5, image 1 of 2 iPhone 6s Battery Connection: step 5, image 2 of 2
    • Use the edge of a spudger to slice through the adhesive on either side of the phone.
  6. iPhone 6s Battery Connection: step 6, image 1 of 2 iPhone 6s Battery Connection: step 6, image 2 of 2
  7. iPhone 6s Battery Connection: step 7, image 1 of 3 iPhone 6s Battery Connection: step 7, image 2 of 3 iPhone 6s Battery Connection: step 7, image 3 of 3
    • Use the suction cup to open the display, breaking the last of the adhesive.
    • Don't open the display more than 90 degrees, as it is still connected at the top by three cables that may break if stretched.
  8. iPhone 6s Battery Connection: step 8, image 1 of 1
    • Lean the display against something to keep it propped up while you're working on the phone.
  9. iPhone 6s Battery Connection: step 9, image 1 of 1
    • Remove the following screws from the battery connector bracket:
    • One 3.0 mm Phillips #00 screw
    • One 2.3 mm Phillips #00 screw
  10. iPhone 6s Battery Connection: step 10, image 1 of 1
    • Remove the metal battery connector bracket from the iPhone.
  11. iPhone 6s Battery Connection: step 11, image 1 of 3 iPhone 6s Battery Connection: step 11, image 2 of 3 iPhone 6s Battery Connection: step 11, image 3 of 3
    • Use the flat end of a spudger to disconnect the battery connector from the logic board.
    • Push the connector to the side to ensure it doesn't accidentally make contact and power on the phone while you're working on it.
Sam Goldheart
465,870 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
135 Members
17,228 Guides authored
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 10
All Time: 415
