iPhone 6 Plus Vibrator Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPhone 6 Plus Vibrator Replacement, Vibrator: step 1, image 1 of 1
    • Pry the vibrator connector cable up from its socket on the logic board with the flat end of a spudger.
  2. iPhone 6 Plus Vibrator Replacement: step 2, image 1 of 2 iPhone 6 Plus Vibrator Replacement: step 2, image 2 of 2
    • Use the tip of a spudger to disconnect the interconnect antenna cable from its socket on the logic board.
  3. iPhone 6 Plus Vibrator Replacement: step 3, image 1 of 2 iPhone 6 Plus Vibrator Replacement: step 3, image 2 of 2
    • Grasp the interconnect antenna cable with a pair of tweezers and carefully deroute it from its channel on the speaker assembly.
  4. iPhone 6 Plus Vibrator Replacement: step 4, image 1 of 1
    • Remove the two 2.5 mm Phillips #00 screws securing the vibrator to the rear case.
  5. iPhone 6 Plus Vibrator Replacement: step 5, image 1 of 1
    • Lift and remove the vibrator out of the iPhone.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 167
