iPhone 6 Plus Vibrator Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. iPhone 6 Plus Vibrator Replacement, Vibrator: step 1, image 1 of 1
      • Pry the vibrator connector cable up from its socket on the logic board with the flat end of a spudger.
      Ask FixBot
    2. iPhone 6 Plus Vibrator Replacement: step 2, image 1 of 2 iPhone 6 Plus Vibrator Replacement: step 2, image 2 of 2
      • Use the tip of a spudger to disconnect the interconnect antenna cable from its socket on the logic board.
      Ask FixBot
    3. iPhone 6 Plus Vibrator Replacement: step 3, image 1 of 2 iPhone 6 Plus Vibrator Replacement: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Grasp the interconnect antenna cable with a pair of tweezers and carefully deroute it from its channel on the speaker assembly.
      Ask FixBot
    4. iPhone 6 Plus Vibrator Replacement: step 4, image 1 of 1
      • Remove the two 2.5 mm Phillips #00 screws securing the vibrator to the rear case.
      Ask FixBot
    5. iPhone 6 Plus Vibrator Replacement: step 5, image 1 of 1
      • Lift and remove the vibrator out of the iPhone.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 9
All Time: 442
