iPhone 6 Plus Rear Facing Camera Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPhone 6 Plus Rear Facing Camera Replacement, Rear Facing Camera: step 1, image 1 of 1
    • Remove the following screws securing the rear-facing camera bracket to the rear case:
    • One 1.7 mm Phillips #00 screw
    • One 2.3 mm Phillips #00 screw
  2. iPhone 6 Plus Rear Facing Camera Replacement: step 2, image 1 of 1
    • Lift and remove the rear-facing camera bracket out of the iPhone.
  3. iPhone 6 Plus Rear Facing Camera Replacement: step 3, image 1 of 1
    • Use the flat end of a spudger to disconnect the rear-facing camera connector from its socket on the logic board.
  4. iPhone 6 Plus Rear Facing Camera Replacement: step 4, image 1 of 1
    • Carefully lift and remove the rear-facing camera out of the iPhone.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 529
