iPhone 6 Plus Rear Facing Camera Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. iPhone 6 Plus Rear Facing Camera Replacement, Rear Facing Camera: step 1, image 1 of 1
      • Remove the following screws securing the rear-facing camera bracket to the rear case:
      • One 1.7 mm Phillips #00 screw
      • One 2.3 mm Phillips #00 screw
      Ask FixBot
    2. iPhone 6 Plus Rear Facing Camera Replacement: step 2, image 1 of 1
      • Lift and remove the rear-facing camera bracket out of the iPhone.
      Ask FixBot
    3. iPhone 6 Plus Rear Facing Camera Replacement: step 3, image 1 of 1
      • Use the flat end of a spudger to disconnect the rear-facing camera connector from its socket on the logic board.
      Ask FixBot
    4. iPhone 6 Plus Rear Facing Camera Replacement: step 4, image 1 of 1
      • Carefully lift and remove the rear-facing camera out of the iPhone.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 17
All Time: 811
