iPhone 6 Plus Power Button Cable Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPhone 6 Plus Power Button Cable Replacement, Power Button Cable: step 1, image 1 of 2 iPhone 6 Plus Power Button Cable Replacement, Power Button Cable: step 1, image 2 of 2
    • Use a pair of tweezers to peel the single adhesive tab that resides on top of both the power button and audio control/rocker switch cable connectors.
  2. iPhone 6 Plus Power Button Cable Replacement: step 2, image 1 of 1
    • Remove the single 1.3 mm Phillips #00 screw securing the power button cable bracket to the rear case.
  3. iPhone 6 Plus Power Button Cable Replacement: step 3, image 1 of 1
    • Carefully grasp the bracket with a pair of tweezers and remove it from the iPhone.
  4. iPhone 6 Plus Power Button Cable Replacement: step 4, image 1 of 1
    • Remove the following screws securing the power button cable bracket to the inner edge of the rear case:
    • One 2.1 mm Phillips #00 screw
    • One 1.7 mm Phillips #00 screw
  5. iPhone 6 Plus Power Button Cable Replacement: step 5, image 1 of 1
    • Grasp the metal bracket covering the power button switch with a pair of tweezers and remove it from the iPhone.
  6. iPhone 6 Plus Power Button Cable Replacement: step 6, image 1 of 1
    • Remove the single 2.1 mm Phillips #00 screw securing the power button switch to the rear case.
  7. iPhone 6 Plus Power Button Cable Replacement: step 7, image 1 of 1
    • Pull the power button switch out of its recess on the rear case with a pair of tweezers.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 183
