Shop the Holiday Gift Guide
iPhone 6 Plus Power Button Cable Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
4
Past 30 Days:
17
All Time:
490
Comments: 0
Go to guide comments
Completed: 0
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
Prereq only for removing power button.
Tools
    1. iPhone 6 Plus Power Button Cable Replacement, Power Button Cable: step 1, image 1 of 2 iPhone 6 Plus Power Button Cable Replacement, Power Button Cable: step 1, image 2 of 2
      Tool used on this step:
      Buy
      • Use a pair of tweezers to peel the single adhesive tab that resides on top of both the power button and audio control/rocker switch cable connectors.
      Ask FixBot
    2. iPhone 6 Plus Power Button Cable Replacement: step 2, image 1 of 1
      • Remove the single 1.3 mm Phillips #00 screw securing the power button cable bracket to the rear case.
      Ask FixBot
    3. iPhone 6 Plus Power Button Cable Replacement: step 3, image 1 of 1
      • Carefully grasp the bracket with a pair of tweezers and remove it from the iPhone.
      Ask FixBot
    4. iPhone 6 Plus Power Button Cable Replacement: step 4, image 1 of 1
      • Remove the following screws securing the power button cable bracket to the inner edge of the rear case:
      • One 2.1 mm Phillips #00 screw
      • One 1.7 mm Phillips #00 screw
      Ask FixBot
    5. iPhone 6 Plus Power Button Cable Replacement: step 5, image 1 of 1
      • Grasp the metal bracket covering the power button switch with a pair of tweezers and remove it from the iPhone.
      Ask FixBot
    6. iPhone 6 Plus Power Button Cable Replacement: step 6, image 1 of 1
      • Remove the single 2.1 mm Phillips #00 screw securing the power button switch to the rear case.
      Ask FixBot
    7. iPhone 6 Plus Power Button Cable Replacement: step 7, image 1 of 1
      • Pull the power button switch out of its recess on the rear case with a pair of tweezers.
      Ask FixBot
Author
with
Walter Galan
711,950 Reputation
1,203 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 17
All Time: 490
