iPhone 6 Plus Battery Connector Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. iPhone 6 Plus Battery Connector Replacement, Battery Connector: step 1, image 1 of 1
      • Remove the following screws from the battery connector bracket:
      • One 2.3 mm Phillips #00 screw
      • One 3.1 mm Phillips #00 screw
      Ask FixBot
    2. iPhone 6 Plus Battery Connector Replacement: step 2, image 1 of 1
      • Remove the metal battery connector bracket from the iPhone.
      Ask FixBot
    3. iPhone 6 Plus Battery Connector Replacement: step 3, image 1 of 1
      • Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
      • Take care to only pry up on the battery connector, and not the socket on the logic board. If you pry up on the logic board socket, you may break the connector entirely.
      Ask FixBot
5 other people completed this guide.
Jeff Suovanen
455,019 Reputation
259 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 17
All Time: 1,889
