iPhone 6 Plus Audio Control and Rocker Switch Cable Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPhone 6 Plus Audio Control and Rocker Switch Cable Replacement, Audio Control and Rocker Switch Cable: step 1, image 1 of 1
    • Remove the following screws securing the audio controls and rocker switch to the rear case:
    • Two 2.0 mm Phillips #00 screws
    • One 2.5 mm Phillips #00 screw
  2. iPhone 6 Plus Audio Control and Rocker Switch Cable Replacement: step 2, image 1 of 3 iPhone 6 Plus Audio Control and Rocker Switch Cable Replacement: step 2, image 2 of 3 iPhone 6 Plus Audio Control and Rocker Switch Cable Replacement: step 2, image 3 of 3
    • Grasp the audio control and rocker switch cable with a pair of tweezers.
    • Slowly peel the audio control and rocker switch cable up off the rear case.
    • Peel with care. The cable is secured to the rear case with mild adhesive.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 206
