iPhone 5s Home Button Assembly Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPhone 5s Home Button Assembly Replacement, Home Button Assembly: step 1, image 1 of 2 iPhone 5s Home Button Assembly Replacement, Home Button Assembly: step 1, image 2 of 2
    • Unscrew the single captive Phillips #000 screw securing the home button cable.
    • The captive screw is fastened to the home button cable by a spring contact backing. During reassembly, ensure the contact is in the correct orientation—on the side of the screw nearest the LCD.
    • If your replacement part does not have this captive screw and spring contact, you will need to transfer them to the new cable.
  2. iPhone 5s Home Button Assembly Replacement: step 2, image 1 of 2 iPhone 5s Home Button Assembly Replacement: step 2, image 2 of 2
    • Fold the home button cable down, out of the way of the home button bracket.
  3. iPhone 5s Home Button Assembly Replacement: step 3, image 1 of 1
    • Remove the two 1.4 mm Phillips #000 screws from the home button bracket.
  4. iPhone 5s Home Button Assembly Replacement: step 4, image 1 of 1
    • Remove the home button bracket from the display assembly.
  5. iPhone 5s Home Button Assembly Replacement: step 5, image 1 of 2 iPhone 5s Home Button Assembly Replacement: step 5, image 2 of 2
    • Wedge the the tip of a spudger underneath the home button cable assembly.
    • The home button cable is affixed by mild adhesive.
    • Gently work the spudger underneath the cable to separate the home button cable from the front panel assembly.
    • Do not remove the home button yet, as it is still attached to the front panel assembly.
  6. iPhone 5s Home Button Assembly Replacement: step 6, image 1 of 2 iPhone 5s Home Button Assembly Replacement: step 6, image 2 of 2
    • If necessary, remove the tape over the home button on the front side of your cracked front panel assembly.
    • Gently push the top left corner of the home button up away from the front panel.
    • Do not push the home button all the way through—you only need to get a corner free, so that you can pry it free with a spudger.
    • This membrane is very thin. If you feel like you're going to tear the button, apply heat and try again.
  7. iPhone 5s Home Button Assembly Replacement: step 7, image 1 of 2 iPhone 5s Home Button Assembly Replacement: step 7, image 2 of 2
    • Peel the home button the rest of the way off of the display by prying gently with a spudger.
  8. iPhone 5s Home Button Assembly Replacement: step 8, image 1 of 1
    • Remove the home button assembly from the front panel.
Sam Goldheart
465,851 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
135 Members
17,193 Guides authored
Past 24 Hours: 0
Past 7 Days: 19
Past 30 Days: 21
All Time: 23,629
