iPhone 5s Battery Connector Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPhone 5s Battery Connector Replacement, Battery Connector: step 1, image 1 of 1
    • Remove the two 1.6 mm Phillips #000 screws securing the metal battery connector bracket to the logic board.
  2. iPhone 5s Battery Connector Replacement: step 2, image 1 of 1
    • Remove the metal battery connector bracket from the iPhone.
  3. iPhone 5s Battery Connector Replacement: step 3, image 1 of 2 iPhone 5s Battery Connector Replacement: step 3, image 2 of 2
    • Use the flat end of a spudger to gently pry the battery connector up from its socket on the logic board.
    • Be very careful to only pry up on the battery connector and not the socket on the logic board. If you pry up on the logic board socket, you may break the connector entirely.
Sam Goldheart
466,174 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,420 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 3,979
