iPhone 5 Rear Case Replacement
Views: 6.9K
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
62
All Time:
6,895
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
In Progress
This guide is a work in progress. Reload periodically to see the latest changes!
Community-Contributed Guide
Better Introduction
Improve this guide by completing or revising its introduction.
Archived Guide This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
Tools
    1. Careful: steps 1-12 are sourced from a guide that's marked as in-progress.
      iPhone 5 Rear Case Replacement, Front Panel: step 1, image 1 of 3 iPhone 5 Rear Case Replacement, Front Panel: step 1, image 2 of 3 iPhone 5 Rear Case Replacement, Front Panel: step 1, image 3 of 3
      • If the display glass is cracked, prevent it from breaking further during the repair, which could cause serious injury. Cover the glass with tape.
      • Apply overlapping layers of clear tape until the entire display is covered.
      • This will keep glass shards contained and maintain structural integrity.
      • Wear safety glasses to protect your eyes from glass shards.
      Ask FixBot
    2. iPhone 5 Rear Case Replacement: step 2, image 1 of 1
      • Before disassembling your iPhone, make sure it is powered off and disconnected from the charger.
      • Remove the two 3.6 mm Pentalobe screws next to the Lightning connector.
      Ask FixBot
    3. iPhone 5 Rear Case Replacement, Opening with an iSclack: step 3, image 1 of 3 iPhone 5 Rear Case Replacement, Opening with an iSclack: step 3, image 2 of 3 iPhone 5 Rear Case Replacement, Opening with an iSclack: step 3, image 3 of 3
      • The next two steps demonstrate the iSclack, a useful tool for opening the iPhone 5. We recommend it for anyone planning more than one repair. If you are not using an iSclack, skip to step 5.
      • Close the iSclack handles to open its suction-cup jaws.
      • Place the iPhone between the suction cups, against the plastic depth gauge.
      • The upper suction cup should be just above the Home button.
      • Open the handles to close the suction cups. Press them firmly against the front and back of the iPhone.
      Ask FixBot
    4. iPhone 5 Rear Case Replacement: step 4, image 1 of 2 iPhone 5 Rear Case Replacement: step 4, image 2 of 2
      • Hold the iPhone securely and close the iSclack handles again to lift the front panel out of the case.
      • The iSclack opening angle is designed to separate the panel and case without damaging the Home button cable.
      • Release the suction cups from the phone.
      • Skip to step 7.
      Ask FixBot
    5. iPhone 5 Rear Case Replacement: step 5, image 1 of 1
      • Attach a suction cup to the screen just above the Home button.
      • Make sure the suction cup is fully and firmly attached to the glass.
      • If the glass is cracked, carefully cover it with several strips of tape. Make sure no air bubbles remain under the suction cup. This helps lift the screen and prevents the cracks from spreading.
      Ask FixBot
    6. iPhone 5 Rear Case Replacement: step 6, image 1 of 1
      • Make sure the suction cup is firmly attached to the front panel.
      • Hold the iPhone with one hand and pull up on the suction cup to slightly separate the front panel from the rear case.
      • Take your time and apply steady force. The display assembly fits more tightly than on most devices.
      • Use a plastic opening tool to gently pry the rear case down, away from the screen, while pulling up on the suction cup.
      • Plastic clips secure the display to the rear case. Use the suction cup and plastic opening tool together to release the display assembly.
      Ask FixBot
    7. iPhone 5 Rear Case Replacement: step 7, image 1 of 1
      • Continue releasing the clips along the left and right sides of the front panel.
      Ask FixBot
    8. iPhone 5 Rear Case Replacement: step 8, image 1 of 2 iPhone 5 Rear Case Replacement: step 8, image 2 of 2
      • Once the bottom and side clips are released, lift the bottom of the display assembly away from the bottom of the phone case.
      • Carefully position the display assembly at about 90 degrees to the case.
      • Do not try to completely separate the front panel from the rear case. Several cables remain connected at the top of the iPhone and can be damaged if handled carelessly.
      Ask FixBot
    9. iPhone 5 Rear Case Replacement: step 9, image 1 of 1
      • Remove the following screws securing the display cable bracket to the logic board:
      • Two 1.2 mm Phillips screws
      • One 1.6 mm Phillips screw
      • Do not use a magnetized screwdriver on this screw. Do not lose it, and make sure it goes back in the correct location. A magnetized screw can interfere with the compass.
      Ask FixBot
    10. iPhone 5 Rear Case Replacement: step 10, image 1 of 2 iPhone 5 Rear Case Replacement: step 10, image 2 of 2
      • Remove the display cable bracket from the logic board.
      • Note: Make sure to disengage the small hooks toward the outside of the phone.
      Ask FixBot
    11. iPhone 5 Rear Case Replacement: step 11, image 1 of 3 iPhone 5 Rear Case Replacement: step 11, image 2 of 3 iPhone 5 Rear Case Replacement: step 11, image 3 of 3
      • Use a plastic opening tool to disconnect the three front panel cables:
      • Front-facing camera and sensor cable
      • Display cable
      • Digitizer cable
      • During reassembly, the display cable may come loose from its connector. This can cause white lines or a blank screen. If this happens, reconnect the cable and restart the phone. The best way to restart it is to disconnect and reconnect the battery.
      Ask FixBot
    12. iPhone 5 Rear Case Replacement: step 12, image 1 of 1
      • Remove the front panel.
      Ask FixBot
    1. Careful: steps 13-17 are sourced from a guide that's marked as in-progress.
      iPhone 5 Rear Case Replacement, Battery: step 13, image 1 of 1
      • Remove the two screws securing the metal battery connector bracket to the logic board:
      • One 1.8 mm Phillips screw
      Ask FixBot
    2. iPhone 5 Rear Case Replacement: step 14, image 1 of 2 iPhone 5 Rear Case Replacement: step 14, image 2 of 2
      • Remove the metal battery connector bracket.
      Ask FixBot
    3. iPhone 5 Rear Case Replacement: step 15, image 1 of 2 iPhone 5 Rear Case Replacement: step 15, image 2 of 2
      • Use a plastic spudger to gently lift the battery connector out of its socket on the logic board.
      • Be very careful to lift only the battery connector, not the socket. Prying up the logic board socket will damage it.
      Ask FixBot
    4. iPhone 5 Rear Case Replacement: step 16, image 1 of 3 iPhone 5 Rear Case Replacement: step 16, image 2 of 3 iPhone 5 Rear Case Replacement: step 16, image 3 of 3
      • Sometimes the battery can be removed by pulling on the plastic tab. Gentle, sustained force works well. If this does not work, follow the instructions in this step.
      • Use a plastic spudger to gently pry the battery up only at the three points shown. Prying at other points risks damaging the logic board.
      Ask FixBot
    5. iPhone 5 Rear Case Replacement: step 17, image 1 of 1
      • Remove the battery.
      Ask FixBot
    1. Careful: steps 18-30 are sourced from a guide that's marked as in-progress.
      iPhone 5 Rear Case Replacement, Logic Board and Rear Camera: step 18, image 1 of 1
      • Use a nonconductive spudger to pry the cellular antenna connector off the logic board next to the speaker.
      Ask FixBot
    2. iPhone 5 Rear Case Replacement: step 19, image 1 of 1
      • Remove the two screws securing the upper logic board bracket to the rear case:
      • One 1.5 mm Phillips screw
      • One 2.3 mm Phillips screw
      Ask FixBot
    3. iPhone 5 Rear Case Replacement: step 20, image 1 of 2 iPhone 5 Rear Case Replacement: step 20, image 2 of 2
      • Remove the upper logic board bracket.
      • Be careful not to damage the small grounding tab next to the rear camera.
      • On newer models, the bracket may be attached to the camera housing and may not come off completely.
      Ask FixBot
    4. iPhone 5 Rear Case Replacement: step 21, image 1 of 3 iPhone 5 Rear Case Replacement: step 21, image 2 of 3 iPhone 5 Rear Case Replacement: step 21, image 3 of 3
      • Use a nonconductive spudger to disconnect the three cables from the logic board:
      • Upper interconnect cable
      • Button assembly cable
      • Lower interconnect cable
      Ask FixBot
    5. iPhone 5 Rear Case Replacement: step 22, image 1 of 1
      • Remove the two 1.3 mm Phillips screws at the bottom inside the case.
      Ask FixBot
    6. iPhone 5 Rear Case Replacement: step 23, image 1 of 1
      • Remove the single 1.2 mm Phillips screw in the center of the device.
      Ask FixBot
    7. iPhone 5 Rear Case Replacement: step 24, image 1 of 2 iPhone 5 Rear Case Replacement: step 24, image 2 of 2
      • Remove the center bracket from the logic board.
      Ask FixBot
    8. iPhone 5 Rear Case Replacement: step 25, image 1 of 2 iPhone 5 Rear Case Replacement: step 25, image 2 of 2
      • Use a nonconductive spudger to disconnect the Lightning connector cable from its socket on the logic board.
      • Gently move the cable away from the logic board.
      Ask FixBot
    9. iPhone 5 Rear Case Replacement: step 26, image 1 of 3 iPhone 5 Rear Case Replacement: step 26, image 2 of 3 iPhone 5 Rear Case Replacement: step 26, image 3 of 3
      • Use a paper clip or SIM eject tool to eject the SIM card tray.
      • Remove the SIM card tray from the iPhone.
      Ask FixBot
    10. iPhone 5 Rear Case Replacement: step 27, image 1 of 1
      • Remove the screws securing the logic board to the case:
      • Two 2.3 mm Phillips screws
      • Three 2.7 mm screws
      • These screws have a Phillips bit pattern, but we found the best removal tool to be a 2.5 mm flathead driver.
      • One non-magnetic 2.7 mm standoff screw
      • These screws resemble Phillips screws, but we recommend using a 2.5 mm flathead screwdriver.
      • To help with reassembly, you can start these screws using the pointed end of a nonconductive spudger.
      Ask FixBot
    11. iPhone 5 Rear Case Replacement: step 28, image 1 of 3 iPhone 5 Rear Case Replacement: step 28, image 2 of 3 iPhone 5 Rear Case Replacement: step 28, image 3 of 3
      • Rotate the logic board toward the battery compartment.
      • Do not try to remove the logic board yet; one cable is still connected.
      • If the flash remains attached to the logic board, remove it with tweezers and put it back in place.
      • Note: when reassembling your device, be sure that the lower interconnect cable is not tucked underneath the logic board.
      Ask FixBot
    12. iPhone 5 Rear Case Replacement: step 29, image 1 of 2 iPhone 5 Rear Case Replacement: step 29, image 2 of 2
      • Use the pointed end of a nonconductive spudger to gently disconnect the Wi-Fi antenna connector from the underside of the logic board.
      Ask FixBot
    13. iPhone 5 Rear Case Replacement: step 30, image 1 of 1
      Tool used on this step:
      Anti-Static Mat
      $24.99
      Buy
      • Remove the logic board.
      • Place the removed logic board on an anti-static mat to protect it from damage.
      Ask FixBot
    1. iPhone 5 Rear Case Replacement, Lightning Connector and Headphone Jack: step 31, image 1 of 2 iPhone 5 Rear Case Replacement, Lightning Connector and Headphone Jack: step 31, image 2 of 2
      • Gently pull the speaker away from the Lightning connector cable.
      • If you are replacing the Lightning connector, transfer the rubber microphone cover to the new part. You can use a plastic spudger to do this.
      Ask FixBot
    2. iPhone 5 Rear Case Replacement: step 32, image 1 of 1
      • Gently remove the grounding cable from the edge of the headphone jack.
      • Take care not to lose the plastic gasket between the headphone connector and the outer shell. While aligning the headphone connector, make sure to align this gasket correctly.
      Ask FixBot
    1. iPhone 5 Rear Case Replacement, Vibrator: step 33, image 1 of 1
      • Remove the two screws securing the vibrator bracket:
      • One 1.7 mm Phillips screw
      Ask FixBot
    2. iPhone 5 Rear Case Replacement: step 34, image 1 of 1
      • Remove the vibrator bracket.
      Ask FixBot
    3. iPhone 5 Rear Case Replacement: step 35, image 1 of 1
      • Remove the 1.6 mm Phillips screw securing the vibrator to the inside top of the case.
      Ask FixBot
    4. iPhone 5 Rear Case Replacement: step 36, image 1 of 2 iPhone 5 Rear Case Replacement: step 36, image 2 of 2
      • Remove the vibrator.
      Ask FixBot
    1. iPhone 5 Rear Case Replacement, Front Panel Clips: step 37, image 1 of 2 iPhone 5 Rear Case Replacement, Front Panel Clips: step 37, image 2 of 2
      • Remove the eight 1.3 mm Phillips screws securing the front panel clips to the rear case.
      Ask FixBot
    2. iPhone 5 Rear Case Replacement: step 38, image 1 of 1
      • Remove the four front panel clips.
      Ask FixBot
    1. Careful: steps 39-43 are sourced from a guide that's marked as in-progress.
      iPhone 5 Rear Case Replacement, Power Button: step 39, image 1 of 2 iPhone 5 Rear Case Replacement, Power Button: step 39, image 2 of 2
      • Use the pointed end of a nonconductive spudger to remove the rubber cushion from underneath the power button.
      Ask FixBot
    2. iPhone 5 Rear Case Replacement: step 40, image 1 of 2 iPhone 5 Rear Case Replacement: step 40, image 2 of 2
      • Remove the screws between the flash and rear camera openings:
      • One 2.9 mm standoff screw
      • This screw resembles a Phillips screw, but we recommend using a 2.5 mm flathead screwdriver.
      • Remove the single 1.9 mm Phillips screw securing the power button bracket to the case.
      Ask FixBot
    3. iPhone 5 Rear Case Replacement: step 41, image 1 of 1
      • Remove the metal power button bracket.
      Ask FixBot
    4. iPhone 5 Rear Case Replacement: step 42, image 1 of 2 iPhone 5 Rear Case Replacement: step 42, image 2 of 2
      • Use the pointed end of a nonconductive spudger to fold the metal bracket away from the top of the case.
      Ask FixBot
    5. iPhone 5 Rear Case Replacement: step 43, image 1 of 3 iPhone 5 Rear Case Replacement: step 43, image 2 of 3 iPhone 5 Rear Case Replacement: step 43, image 3 of 3
      • Press the power button from the outside with the pointed end of a spudger.
      • Remove the power button.
      Ask FixBot
    1. Careful: steps 44-46 are sourced from a guide that's marked as in-progress.
      iPhone 5 Rear Case Replacement, Power and Volume Button Cable: step 44, image 1 of 2 iPhone 5 Rear Case Replacement, Power and Volume Button Cable: step 44, image 2 of 2
      • Use a plastic spudger to slide the power button bracket up and to the left, releasing it from its metal retaining loop.
      Ask FixBot
    2. iPhone 5 Rear Case Replacement: step 45, image 1 of 2 iPhone 5 Rear Case Replacement: step 45, image 2 of 2
      • Use the flat end of a spudger to lift the cable and release its adhesive.
      Ask FixBot
    3. iPhone 5 Rear Case Replacement: step 46, image 1 of 3 iPhone 5 Rear Case Replacement: step 46, image 2 of 3 iPhone 5 Rear Case Replacement: step 46, image 3 of 3
      • Continue prying the cable near the volume buttons.
      • Remove the cable.
      • If the replacement part does not include the metal bracket, warm the old cable with a hair dryer to soften the adhesive so you can transfer the bracket to the replacement cable.
      Ask FixBot
    1. iPhone 5 Rear Case Replacement, Rear Case: step 47, image 1 of 2 iPhone 5 Rear Case Replacement, Rear Case: step 47, image 2 of 2
      • Remove the 2.0 mm Phillips screw securing the SIM card eject lever.
      • Remove the SIM card eject lever.
      Ask FixBot
    2. iPhone 5 Rear Case Replacement: step 48, image 1 of 1
      • Only the bare rear case remains.
      Ask FixBot
3 other people completed this guide.
Alexander Zenchenko
1,046 Reputation
2 Guides authored
Ru Translators iFixit Member of Ru Translators iFixit
Community
17 Members
73 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 62
All Time: 6,895
