iPhone 4S Headphone Jack Cable Assembly Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPhone 4S Headphone Jack Cable Assembly Replacement, Headphone Jack Cable Assembly: step 1, image 1 of 3 iPhone 4S Headphone Jack Cable Assembly Replacement, Headphone Jack Cable Assembly: step 1, image 2 of 3 iPhone 4S Headphone Jack Cable Assembly Replacement, Headphone Jack Cable Assembly: step 1, image 3 of 3
    • Use the edge of a plastic opening tool to dislodge the headphone jack off from its recess in the outer case.
    • Use the edge of a plastic opening tool to peel the top microphone away from the outer case.
    • Pull the body of the headphone jack away from the top edge of the iPhone.
  2. iPhone 4S Headphone Jack Cable Assembly Replacement: step 2, image 1 of 1
    • Remove the 1.6 mm Phillips screw securing the mute switch bracket to the outer case.
  3. iPhone 4S Headphone Jack Cable Assembly Replacement: step 3, image 1 of 1
    • Remove the four 1.5 mm Phillips screws securing the volume button and silent switch brackets to the outer case.
  4. iPhone 4S Headphone Jack Cable Assembly Replacement: step 4, image 1 of 1
    • Use a pair of tweezers to gently pull the silent switch bracket away from the outer case.
  5. iPhone 4S Headphone Jack Cable Assembly Replacement: step 5, image 1 of 1
    • Carefully peel the headphone jack/volume button cables off the adhesive securing them to the rear case.
    • Remove the headphone jack cable assembly from the iPhone.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 1,794
