iPhone 4S Headphone Jack Cable Assembly Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPhone 4S Headphone Jack Cable Assembly Replacement, Headphone Jack Cable Assembly: step 1, image 1 of 3 iPhone 4S Headphone Jack Cable Assembly Replacement, Headphone Jack Cable Assembly: step 1, image 2 of 3 iPhone 4S Headphone Jack Cable Assembly Replacement, Headphone Jack Cable Assembly: step 1, image 3 of 3
    • In this step, be careful not to remove the headphone jack without first separating the top microphone from the upper case, as they are connected by a fragile flex cable.
    • Use a plastic opening tool to start to pry the headphone jack out of its recess in the rear case.
    • Then use the opening tool to gently peel the microphone up from the adhesive securing it to the top of the rear case.
    • Remove the headphone jack assembly from the rear case, being careful not to tear the microphone flex cable.
  2. iPhone 4S Headphone Jack Cable Assembly Replacement: step 2, image 1 of 1
    • Remove the 1.6 mm Phillips screw securing the mute switch bracket to the outer case.
  3. iPhone 4S Headphone Jack Cable Assembly Replacement: step 3, image 1 of 1
    • Remove the four 1.5 mm Phillips screws securing the volume button and silent switch brackets to the outer case.
  4. iPhone 4S Headphone Jack Cable Assembly Replacement: step 4, image 1 of 1
    • Use a pair of tweezers to gently pull the silent switch bracket away from the outer case.
  5. iPhone 4S Headphone Jack Cable Assembly Replacement: step 5, image 1 of 1
    • Carefully peel the headphone jack/volume button cables off the adhesive securing them to the rear case.
    • Remove the headphone jack cable assembly from the iPhone.
3 other people completed this guide.
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 3
All Time: 1,782
