Shop the Holiday Gift Guide
iPhone 17 Pro USB-C Installation
View statistics:
Past 24 Hours:
0
Past 7 Days:
8
Past 30 Days:
21
All Time:
111
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Parts
Tools
    1. iPhone 17 Pro USB-C Installation, Install the USB-C port assembly: step 1, image 1 of 3 iPhone 17 Pro USB-C Installation, Install the USB-C port assembly: step 1, image 2 of 3 iPhone 17 Pro USB-C Installation, Install the USB-C port assembly: step 1, image 3 of 3
      • Carefully inspect your replacement USB-C port assembly and remove any adhesive liners.
      • Align the assembly with the bottom edge of the frame and lay it loosely in place.
      • Make sure the assembly tucks below the black plastic speaker channel.
      Ask FixBot
    2. iPhone 17 Pro USB-C Installation: step 2, image 1 of 3 iPhone 17 Pro USB-C Installation: step 2, image 2 of 3 iPhone 17 Pro USB-C Installation: step 2, image 3 of 3
      • The metal mounting tab near the top of the USB-C port assembly has a bend that has to sit underneath the logic board.
      • Tuck the metal mounting tab's bend underneath the logic board. When it's properly positioned, the mounting tab's screw hole should line up correctly.
      Ask FixBot
    3. iPhone 17 Pro USB-C Installation: step 3, image 1 of 2 iPhone 17 Pro USB-C Installation: step 3, image 2 of 2
      • Use a JIS 00 screwdriver to install the two 3.3 mm‑long USB-C port screws to the bottom edge of the frame.
      • Make sure to install these screws in the holes marked in green, not red.
      Ask FixBot
    4. iPhone 17 Pro USB-C Installation: step 4, image 1 of 2 iPhone 17 Pro USB-C Installation: step 4, image 2 of 2
      • Install the USB-C port assembly screws:
      • Three 1.5 mm‑long JIS 00 screws
      • Two 1.7 mm‑long JIS 00 screws
      • One 1.3 mm‑long JIS 00 screw
      • One 1.2 mm‑long Y000 screw
      • If your iPhone doesn't have mmWave functionality, you may not have this screw.
      Ask FixBot
    5. iPhone 17 Pro USB-C Installation: step 5, image 1 of 1
      • Use a JIS 00 screwdriver to install the 1.2 mm‑long USB-C port assembly screw to the bottom left corner of the frame.
      Ask FixBot
    6. iPhone 17 Pro USB-C Installation: step 6, image 1 of 1
      • Use a JIS 00 screwdriver to install the 1.2 mm‑long USB-C port assembly screw to the right edge of the frame.
      Ask FixBot
    7. iPhone 17 Pro USB-C Installation: step 7, image 1 of 3 iPhone 17 Pro USB-C Installation: step 7, image 2 of 3 iPhone 17 Pro USB-C Installation: step 7, image 3 of 3
      Tool used on this step:
      Tesa 61395 Tape
      $2.95
      Buy
      • If the microphone adhesive gasket isn't deformed and your replacement USB-C port assembly didn't come with adhesive, you can reuse the existing gasket. Be aware that you'll lose water and dust resistance.
      • Use tweezers to remove the adhesive from where the microphone attaches to the frame.
      • You can use some double-sided tape as a replacement adhesive. Use a pin to poke a hole through the tape. Enlarge it enough for the mic hole, then apply the tape to the microphone.
      • Use your finger to align and press the microphone module onto the frame.
      Ask FixBot
    8. iPhone 17 Pro USB-C Installation: step 8, image 1 of 1
      • Use a hair dryer or an iOpener to heat the entire USB-C port assembly until it's warm to the touch. This helps the adhesive to bond better.
      Ask FixBot
    9. iPhone 17 Pro USB-C Installation: step 9, image 1 of 2 iPhone 17 Pro USB-C Installation: step 9, image 2 of 2
      • Use your finger to press and connect the two USB-C port assembly press connectors (one's underneath the other) to the logic board.
      Ask FixBot
Arthur Shi
353,975 Reputation
938 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 21
All Time: 111
